Turn signal lens, Need to replace! |
Ian Stott |
Aug 1 2021, 06:21 AM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
Time to replace the front turn signal lenses, mine are the standard Amber. I have seen in the past there were lenses that were dark purple and white, are they still available and who has them?
Thanks! Ian Stott Moncton Canada |
Shivers |
Aug 1 2021, 08:05 AM
Senior Member Group: Members Posts: 2,675 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I looked all over the place, could only fine the usual suspects. But clear is here: https://www.pelicanparts.com/More_Info/N14R...ABoCjhwQAvD_BwE
And with a glass color tint something like this: https://www.amazon.com/Krylon-K09027000-Sta...e/dp/B01HP2HNTG , sprayed inside you could have any color they sell. There are spray tints that deal with the heat of a light source. |
fixer34 |
Aug 1 2021, 08:09 AM
Senior Member Group: Members Posts: 1,160 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
Time to replace the front turn signal lenses, mine are the standard Amber. I have seen in the past there were lenses that were dark purple and white, are they still available and who has them? Thanks! Ian Stott Moncton Canada Not sure about Canada, but in the states, they are rather fussy about the lenses color. Parking lights and turn signals have to be amber. |
Mikey914 |
Aug 1 2021, 08:29 AM
The rubber man Group: Members Posts: 12,711 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Time to replace the front turn signal lenses, mine are the standard Amber. I have seen in the past there were lenses that were dark purple and white, are they still available and who has them? Thanks! Ian Stott Moncton Canada Not sure about Canada, but in the states, they are rather fussy about the lenses color. Parking lights and turn signals have to be amber. We have the clear, and our customers have done some cool stuff to them - Fron the side marker GB thread - http://www.914world.com/bbs2/index.php?sho...54483&st=25 More pics in thread Attached thumbnail(s) |
Mikey914 |
Aug 1 2021, 08:30 AM
Another angle -
Attached image(s) |
Mikey914 |
Aug 1 2021, 08:31 AM
@Rfinegan did a really good job here. I'm sure you could use any color you want, but your local law enforcement may have some restrictions.
NARP74 |
Aug 1 2021, 08:33 AM
Senior Member Group: Members Posts: 1,175 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I've only seen amber, Euro, clear and smoke for the lenses.
https://sierramadrecollection.com/914-914-6...og-lights-c664/ |
Ian Stott |
Aug 1 2021, 08:41 AM
Time to replace the front turn signal lenses, mine are the standard Amber. I have seen in the past there were lenses that were dark purple and white, are they still available and who has them? Thanks! Ian Stott Moncton Canada Not sure about Canada, but in the states, they are rather fussy about the lenses color. Parking lights and turn signals have to be amber. Good point about law enforcement, better stick with the amber, as I do go stateside. Covid has kept me in my home province, restrictions slowly easing. Was less than 100 yards from the US yesterday, I waved! |
bbrock |
Aug 1 2021, 08:48 AM
I think fiddling with turn signal, brake, and tail light colors is just asking for trouble beyond just a possible ticket. If you see a flashing amber light on the corner of a vehicle, you instantly know a turn signal is on. If someone sees a flashing purple light, the are more likely to be confused. Our cars are hard enough for monster trucks to see as it is. Consistent uniformity adds safety.
StarBear |
Aug 1 2021, 08:55 AM
Advanced Member Group: Members Posts: 2,054 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
I think fiddling with turn signal, brake, and tail light colors is just asking for trouble beyond just a possible ticket. If you see a flashing amber light on the corner of a vehicle, you instantly know a turn signal is on. If someone sees a flashing purple light, the are more likely to be confused. Our cars are hard enough for monster trucks to see as it is. Consistent uniformity adds safety. (IMG:style_emoticons/default/agree.gif) Keep it simple and clean. |
Mikey914 |
Aug 1 2021, 09:01 AM
It is amazing how much amber does show through in the smoke when an amber LED is used. In all fairness, it's not a bright so in the daylight it might not be as easily seen.
Attached image(s) |
bbrock |
Aug 1 2021, 09:41 AM
It is amazing how much amber does show through in the smoke when an amber LED is used. In all fairness, it's not a bright so in the daylight it might not be as easily seen. I did something similar on my tail running lights. I run Euro lenses but US DOT wants to see amber side markers on the front of the car and red on the rear. Their argument is that it lets other drivers know which direction your car is moving. I put red LED bulbs in the rear side marker slots which show as red through the amber lens when turned on. Turn signals have amber bulbs and still show as amber. Personally, I think any side markers that increase visibility of the car without distracting other drivers is fine so go nuts. DOT is more picky but I think those smoked side markers would pass their requirements. |
infraredcalvin |
Aug 1 2021, 03:47 PM
Distracted Member Group: Members Posts: 1,552 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
My 6 seems to get a lot of attention when on the road, the gt flares make it seem so much bigger than a narrow body car. But I had a lot of issues with people not seeing my narrow body 4. When I’d flat tow I started to put the running lights on at night so the side marker lights were on. I constantly saw people swerving back to their lane cause they waited for my suv to pass, so they could change lanes not realizing the car was being pulled back there.
Lo-Fi Version | Time is now: 27th September 2024 - 09:23 AM |
