What are the symptoms of a bad rear wheel bearing?, I hear a whir of some sort but it could just be how 914's sound? |
second wind |
Sep 17 2021, 11:02 PM
Senior Member Group: Members Posts: 860 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Hey gang....I have noticed a whiring sound around the back of my '73 2.0 that I only hear when near a K rail or a curb or something that reflecks the sound. I am not sure if it is just routine engine noise or an issue? Mostly drivers side. CV's are fairly new. No other symptoms but just driving my analytical mind crazy. Any thoughts? Thank you very much.
gg |
SirAndy |
Sep 17 2021, 11:25 PM
Resident German Group: Admin Posts: 41,815 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Bad bearing is a low frequency grinding noise
(IMG:style_emoticons/default/smash.gif) |
wonkipop |
Advanced Member Group: Members Posts: 4,624 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
i had a whine in mine after i got it up and running after a long period static.
discovered it was the tyres. i put some micheline XAS on it. they were very noisy until they broke in a bit. hard to know. its terrible having an imagination thats always on the lookout. (IMG:style_emoticons/default/beerchug.gif) |
jcd914 |
Sep 17 2021, 11:48 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I always disliked diagnosing wheel bearings if the were not getting pretty loud. The ones that are just making a little noise are hard to isolate & locate.
Wheel bearing noise tends changes with vehicle speed and load. Faster is typically louder. Changes in side loading often changes the tone of the noise. The side with the bad bearing tend to be loudest when under more load. If while you are along a wall that reflects the sound, you can safely speed up, slow down, swerve slightly right or left, you can start tracking the sound. You may be able to ID the side it is coming from. Or that it is something other than wheel bearings, uneven tire wear can cause road noise. I had a customers car once that I kept hearing a squealy type noise as I accelerated up a freeway on-ramp that had a brick sound wall along it. It took several trips up the ramp to figure up it was tire noise as they broke loose when the engine came up on boost. It took few more trips up the on-ramp to confirm my diagnosis. Sometime diagnosis can be fun. Jim |
second wind |
Sep 18 2021, 01:04 AM
Thank you....no grinding sound anywhere on the car. So the rear bearings sound like a bad front bearing....grind grind grind? Have changed front bearings and grinding sound went away. Hmmm, I wonder what this sound is? I will report back...thank you very much ! gg |
rjames |
Sep 18 2021, 02:06 AM
I'm made of metal Group: Members Posts: 4,111 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
When my right rear wheel bearing was bad it sounded more like a howling sound. Turning one direction made it go away- dead giveaway for a bad bearing.
To rule out your tires you could swap the rears with the fronts. If the sound moves, you've found the problem. |
914Sixer |
Sep 18 2021, 08:14 AM
914 Guru Group: Members Posts: 8,989 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Easy way to check is jack up rear wheel. Grab tire and try and move it up and down or side to side. If any movement occurs you have a bad wheel bearing.
dr914@autoatlanta.com |
Sep 18 2021, 09:09 AM
914 Guru Group: Members Posts: 8,055 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
drive down the road at speed and move the wheel hard left then hard right and if the sound changes it is a rear wheel bearing
930cabman |
Sep 18 2021, 05:11 PM
Advanced Member Group: Members Posts: 3,545 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I am thinking we have a bad rear wheel bearing in our 1975 914/4. The PO informed me of a bad bearing and gave me a new one. Often the drivers side rear wheel makes some noise, it increases with load and reduces when coasting. I cannot feel any looseness or weird noises when on the lift. It looks straight forward to replace them.
Lo-Fi Version | Time is now: 27th September 2024 - 09:12 AM |
