appropriate 73' 914 2.0 speedo?, Is this a matching 73' 2.0 speedometer? |
914lover17 |
Oct 6 2021, 11:56 AM
Newbie Group: Members Posts: 45 Joined: 11-June 21 From: Kitchener-Waterloo Member No.: 25,622 Region Association: Canada |
mihai914 |
Oct 6 2021, 12:35 PM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
Yes
914Sixer |
914 Guru Group: Members Posts: 8,988 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Only difference between -6 and -4 is the weight in speedometer. -6 is at .8 and the -4 is .77. Early -4 had 155SR15 and used the 120 speedo. All the 914's with 165SR15 used the 150 speedo. -6 always used the 911 speedo.
911, 914-6 speedo usually cost more. With all the tire combo's available there should be no real difference in accuracy. IF the above speedo is a 914-6 it will have 911.641.502. 00 or 01 |
914lover17 |
Oct 6 2021, 01:06 PM
Only difference between -6 and -4 is the weight in speedometer. -6 is at .8 and the -4 is .77. Early -4 had 155SR15 and used the 120 speedo. All the 914's with 165SR15 used the 150 speedo. -6 always used the 911 speedo. 911, 914-6 speedo usually cost more. With all the tire combo's available there should be no real difference in accuracy. IF the above speedo is a 914-6 it will have 911.641.502. 00 or 01 It's 911 641 502 01 I have maxilite (I think) 6x15 replica fuchs with 185/70 VR 15 |
914Sixer |
Oct 6 2021, 01:49 PM
Put a WTB in classifieds, some one will be able to fix up up reasonably.
Lo-Fi Version | Time is now: 27th September 2024 - 06:03 AM |
