Sun Visor issues, Sun visors too long for front roof latches |
Radio2115 |
Mar 12 2022, 01:58 PM
Newbie Group: Members Posts: 8 Joined: 12-November 20 From: Colorado Member No.: 24,879 Region Association: None |
I'm sure that I must be doing something wrong here but when installed on my '70 914, the sun visors don't allow the front roof latches to drop down or reconnect as the ends of the visors are in the way. Even when pushed all the way to the center clip. Wrong visors? Wrong clips? Wrong process?
bkrantz |
Mar 12 2022, 08:59 PM
914 Guru Group: Members Posts: 8,065 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Photo?
Bartlett 914 |
Mar 12 2022, 09:15 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I have replacement visors in my car. I had the same issue. There wasn't enough room to release the latches. My solution was to add a 1/4" spacer under the attachment at the outer ends. It is not visible. The clearance is better an works for me
GregAmy |
Mar 12 2022, 09:27 PM
Advanced Member Group: Members Posts: 2,385 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Shivers |
Mar 12 2022, 09:48 PM
Senior Member Group: Members Posts: 2,674 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Photo? Right. Not sure what the issue is, but I put bi-fold Miata visors in my street car, and the outer side extends across where the latch is. I simply rotate the visors perpendicular to the header then work the latches, and move them back afterward. I haven't had them on my car in years, but I'm pretty sure that is how I had to do mine when I did. I pushed them forward to the wind screen and did the latches. I do not know if this will work for you since I can not see your exact problem (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
gereed75 |
Mar 13 2022, 06:06 AM
Senior Member Group: Members Posts: 1,286 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
Yep, they do obstruct the latch mechanism a bit. Gotta finagle around it.
Not too big of a deal removing the roof but you must make sure that you slide the latch above the visor when installing the roof or you won’t be able to engage the latch catch to close the latch. Part of the drill Enjoy your new toy |
Radio2115 |
Mar 13 2022, 01:21 PM
Sorry, I get the distinct impression pics are in order! As you see there is no way to move the visor out of the way in any angle to allow the clips to unlatch. It sounds like perhaps a spacer to lower the visor is the only option. I'm just puzzled as to why it's a peroblem in the first place!
Cairo94507 |
Mar 13 2022, 02:06 PM
Michael Group: Members Posts: 10,022 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I just installed a set of 914 Rubber visors in my car. For mine, I just unlatch all 4 latches and lift the back of the roof up first and then slide the top towards the rear and lift it. Where I have an issue is putting the visors up and down as they rub a bit on the pad. I think I will just put a 1/8" washer under the mounts to give it a bit more space and that will resolve that. (IMG:style_emoticons/default/beerchug.gif)
Radio2115 |
Mar 13 2022, 02:27 PM
Spacers and sliding the top back to clear the visors are both perfect answers that were staring me in the face! Sometimes it's better not to try and solve a problem until it becomes one!
jvmarino |
Mar 13 2022, 08:27 PM
Member Group: Members Posts: 89 Joined: 22-March 09 From: Baltimore Member No.: 10,188 Region Association: None |
I think your problem is you have the brackets on wrong. They should project toward the windshield, not the seating area. Swap the locations of the 2 outer ones and flip the center one.
GregAmy |
Mar 14 2022, 05:42 AM
I think your problem is you have the brackets on wrong. They should project toward the windshield, not the seating area. Swap the locations of the 2 outer ones and flip the center one. Good eye, nice catch! (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 07:11 AM |
