WTB: Timing Hole Plug FOUND, Plug With Hose Fitting |
Jim C |
Apr 6 2022, 12:13 PM
Member Group: Members Posts: 206 Joined: 11-July 19 From: Texas Member No.: 23,294 Region Association: Southwest Region |
I am searching for a timing hole plug for the cooling fan shroud that supposedly came with the dealer installed A/C kit. This plug would have a fitting to accept a hose from the engine compartment mounted charcoal cannister and would have been used on 75 - 76 2.0 liters.
bdstone914 |
Apr 6 2022, 06:54 PM
bdstone914 Group: Members Posts: 4,673 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I am searching for a timing hole plug for the cooling fan shroud that supposedly came with the dealer installed A/C kit. This plug would have a fitting to accept a hose from the engine compartment mounted charcoal cannister and would have been used on 75 - 76 2.0 liters. Never seen or heard of what you describe. A port on the timing plug will draw air into the fan. The canister need air input and the output into the intake. |
ClayPerrine |
Apr 7 2022, 05:31 AM
Life's been good to me so far..... Group: Admin Posts: 15,820 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I am searching for a timing hole plug for the cooling fan shroud that supposedly came with the dealer installed A/C kit. This plug would have a fitting to accept a hose from the engine compartment mounted charcoal cannister and would have been used on 75 - 76 2.0 liters. Never seen or heard of what you describe. A port on the timing plug will draw air into the fan. The canister need air input and the output into the intake. They exist. Betty's car had one on it when she first got it. It was done to replace charcoal canister connection on cars with dealer installed AC. The compressor mount blocks the original fitting. Clay |
TheCabinetmaker |
Apr 7 2022, 07:26 AM
I drive my car everyday Group: Members Posts: 8,309 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
My 73 had ac with that fitting.
KevinW |
Apr 7 2022, 04:03 PM
Newbie Group: Members Posts: 42 Joined: 25-May 15 From: Winona, Minnesota Member No.: 18,761 Region Association: Upper MidWest |
I have this one that I don’t need.
Attached thumbnail(s) |
Jim C |
Apr 8 2022, 06:33 AM
JeffBowlsby |
Apr 8 2022, 10:51 AM
914 Wiring Harnesses Group: Members Posts: 8,663 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Al Meredith |
Apr 8 2022, 02:45 PM
Senior Member Group: Members Posts: 967 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
I have one and there is no S/N on it . I looked in the AA catalog and George doesn't show one with a hose fitting . If Jim's deal does not go through Mine is available. Al
KevinW |
Apr 8 2022, 03:45 PM
Superhawk996 |
Apr 8 2022, 05:34 PM
914 Guru Group: Members Posts: 6,469 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I have this one that I don’t need. KevinW is the best for coming to rescue with parts! (IMG:style_emoticons/default/first.gif) |
Van B |
Apr 9 2022, 01:36 PM
Senior Member Group: Members Posts: 1,616 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
@Jim C
I can’t believe someone had one of those lol!!! |
Al Meredith |
Apr 10 2022, 05:08 PM
I have a lot of parts like that , My Son says it is for a 1.8L AL
Lo-Fi Version | Time is now: 27th September 2024 - 10:11 AM |
