Crankshaft gear dots, Two gears with dots in different locations |
Phoenix914 |
Jun 7 2022, 05:47 PM
Member Group: Members Posts: 389 Joined: 6-December 06 From: Oviedo, FL Member No.: 7,322 Region Association: South East States |
I decided to buy a new crankshaft gear because the machine shop gouged mine with a tool while disassembling the crankshaft. The new gear I bought at a local VW parts store has the two dots located one tooth over from the gear that came out of my engine. Which one is correct? The part number on the new gear is right, so now I'm not sure which gear to use.
I can simply drill some new holes in the new gear to match the old one, but can anyone confirm which one has the righ marks? New gear and box at the top, old gear at the bottom: Thanks for any help! |
Jake Raby |
Jun 7 2022, 09:50 PM
Engine Surgeon Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
the new gear looks small, like a Type 1 gear. compare the diameters.
Phoenix914 |
Jun 7 2022, 10:26 PM
the new gear looks small, like a Type 1 gear. compare the diameters. Thanks for the reminder, I should have included that information in the original post. The image is distorted and does appear to show the gears to be different sizes. Upon measurement, they are identical in diameter (~75.3 mm) and thickness (~21.25 mm). The new gear is on the right in this picture: Can you think of or do you notice anytihing else from that picture? They appear identical to me except for the marks. Maybe that's why the guy at the parts store said they've had it for a long time. |
porschetub |
Jun 7 2022, 11:59 PM
Advanced Member Group: Members Posts: 4,725 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
the new gear looks small, like a Type 1 gear. compare the diameters. Thanks for the reminder, I should have included that information in the original post. The image is distorted and does appear to show the gears to be different sizes. Upon measurement, they are identical in diameter (~75.3 mm) and thickness (~21.25 mm). The new gear is on the right in this picture: Can you think of or do you notice anytihing else from that picture? They appear identical to me except for the marks. Maybe that's why the guy at the parts store said they've had it for a long time. Confused what the issue your old one ? this gear is as hard as hell and hard to damage ,someone on the WTD section would most likely just about give you one with shipping paid. IMO I would be worried about your engine guy as it appears it was removed with the wrong press and not hot enough,just saying ok ,cheers |
Jake Raby |
Jun 8 2022, 07:07 AM
The dot location on the replacement leads me to believe it is a replacement made by Sebro a few years ago.
I have seen these have too large of an OD, fit too loose and create a failure years later. I only use original, genuine gears. Thanks for conforming the diameters are the same. |
Phoenix914 |
Jun 8 2022, 08:26 AM
Confused what the issue your old one ? this gear is as hard as hell and hard to damage ,someone on the WTD section would most likely just about give you one with shipping paid. IMO I would be worried about your engine guy as it appears it was removed with the wrong press and not hot enough,just saying ok ,cheers The damage is on the other side of the gear. I guess they pried on it with something instead of using the right tools and heat, as you said. I gave that machine shop a few simple tasks and they failed at most of them. The rest of my components have been handled by reputable professionals, even though it cost $$ to ship heavy objects across the country! [quote name='Jake Raby' date='Jun 8 2022, 09:07 AM' post='3007306'] The dot location on the replacement leads me to believe it is a replacement made by Sebro a few years ago. I have seen these have too large of an OD, fit too loose and create a failure years later. I only use original, genuine gears. Thanks for conforming the diameters are the same. [/quoteTD Thank you both for the advice - I'll check out the WTD section to find a good, genuine replacement gear. |
Jake Raby |
Jun 8 2022, 09:54 AM
That was an idiot with a chisel, or an air hammer with a chisel bit.
porschetub |
Jun 9 2022, 08:44 PM
That was an idiot with a chisel, or an air hammer with a chisel bit. Holy s#it what a mess ,all the damage done on that part !!!!!!!,probably a good idea to check the crank for burrs and the fit of the dizzy drive brass gear,after being dealt to by a total dick,good luck sorting this. |
Lo-Fi Version | Time is now: 27th September 2024 - 10:06 AM |
