914 fuse confirmation |
MM1 |
Jul 24 2022, 12:02 PM
914 obsession continues Group: Members Posts: 619 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
I’m trying to replace fuses in the 914 which I’ve never done before. Can you please tell me if this diagram is correct? (I got it from a thread on 914 World.) It shows that all fuses are 8 amp except for the wiper motor which is 16 amp-it says the two fuses that are to the far right are an 8 and a 16 for unused circuits.
The picture of mine shows it has a 16 amp in the first slot to the left which is a tail lamp and luggage lamp-if the diagram is correct this should be an eight amp. |
FlacaProductions |
Jul 24 2022, 12:26 PM
Senior Member Group: Members Posts: 1,739 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
If this is for your 73:
https://bowlsby.net/914/Classic/zTN_Elect_73FuseIndex.pdf |
MM1 |
Jul 24 2022, 04:22 PM
Sorry - I am asking about the 1974.
So the 1st picture I found on 914World is invalid? I found this thread which has a link to Jeff Bowlsby's 1974 fuse index: http://www.914world.com/bbs2/index.php?s=&...t&p=2756960 https://bowlsby.net/914/Classic/zTN_Elect_FuseIndex.jpg Jeff's index above lists 16A fuses for slots 8,10 and 12 (8A for the rest) - can anyone confirm? My 1974 has no fog lamps (slot 10 according to Jeff) - should I use a 16A anyway, or just an 8A? |
DC_neun_vierzehn |
Jul 24 2022, 04:31 PM
Member Group: Members Posts: 438 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
Do you have the owners manual? It’s listed there. If not, ask someone with a 74 manual.
MM1 |
Jul 24 2022, 05:38 PM
Don't have one - great idea - does anyone have a 1974 manual (pics of the fuses)?
FlacaProductions |
Jul 24 2022, 05:53 PM
The one you found from Jeff's site for the 74 is right for a 74.
SirAndy |
Jul 24 2022, 06:37 PM
Resident German Group: Admin Posts: 41,815 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
So the 1st picture I found on 914World is invalid? Never seen the picture before. It doesn't seem right. (IMG:style_emoticons/default/idea.gif) |
MM1 |
Jul 24 2022, 09:56 PM
Thank you, Sirs.
I shall adhere to Master Bowlsby’s direction. I’ll use a 16A for slot 10 even though this ‘74 has no fog lamps. |
JeffBowlsby |
Jul 24 2022, 10:33 PM
914 Wiring Harnesses Group: Members Posts: 8,663 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
You will need fuse 10 for your horn, just be sure to check your fog circuits to prevent a short to ground.
wonkipop |
Jul 24 2022, 10:47 PM
Advanced Member Group: Members Posts: 4,624 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
74 owners manual.
MM1 |
Jul 25 2022, 11:50 AM
Thank you, Gents!
dr914@autoatlanta.com |
Jul 25 2022, 01:18 PM
914 Guru Group: Members Posts: 8,055 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
owners manual or appendix of the book 914 "tech tips 700" the 70-73 used 8 and 25 the 74-76 8 and 16 amp fuses. Please make sure you put a fuse cover over the fuses when you are done, too easy to knock them out when getting in and out of the car
StarBear |
Jul 25 2022, 01:19 PM
Advanced Member Group: Members Posts: 2,054 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
owners manual or appendix of the book 914 "tech tips 700" the 70-73 used 8 and 25 the 74-76 8 and 16 amp fuses. Please make sure you put a fuse cover over the fuses when you are done, too easy to knock them out when getting in and out of the car (IMG:style_emoticons/default/agree.gif) |
MM1 |
Jul 25 2022, 05:37 PM
Thank you all.
I just replaced them all as instructed and then replaced a relay on the driver side headlight and now everything appears to work. . . I just need to figure out how to get the thing running which is a whole different thread. Of course I bought a fuse box cover a while back here on 914 World and I can’t find it. If anyone has one available regardless of condition please PM me. Otherwise I’ll do a WTB thread. Current condition: |
MM1 |
Jul 25 2022, 05:43 PM
owners manual or appendix of the book 914 "tech tips 700" the 70-73 used 8 and 25 the 74-76 8 and 16 amp fuses. Please make sure you put a fuse cover over the fuses when you are done, too easy to knock them out when getting in and out of the car So for my 1973 1.7L I can do the same layout (as Jeff’s index above) for fuses one through 12 but substitute 25A for the 16A slots (slots 8,10 and 12 )in the 1974? |
wonkipop |
Jul 25 2022, 06:12 PM
@MM1
not sure if you are mixing it up there just from the way you have written that but i think you have it correct if i am reading you right. for clarity. 74s have the 16 amp fuses (see my post above of page from owners manual for a 74 1.8, as you asked for. that is from my car and correct manual). for a 73. posted here is the fusebox page from the 73 owners manual that i have on file. its a 25 amp fuse being used. advice by dr. 914 above correct. 73 owners manual. |
MM1 |
Jul 25 2022, 06:17 PM
Yes Sir - that’s what I meant.
Your 1973 manual pic seals it-thank you, Sir. If you ever make it to SoCal lunch or dinner is on me! |
wonkipop |
Jul 25 2022, 06:23 PM
Yes Sir - that’s what I meant. Your 1973 manual pic seals it-thank you, Sir. If you ever make it to SoCal lunch or dinner is on me! you never know. MM1 i've got old friends in LA from Chicago i have not seen in years. i was intending to get across before covid messed up the world. might still make it one day if i can stomach the day long plane flight backwards in time. have a grand plan to drive from calif to texas. co-incidently my initials are MM - thats my nickname amongst mates. (IMG:style_emoticons/default/beerchug.gif) |
MM1 |
Jul 25 2022, 08:56 PM
Well, here’s to meetin’ ya one day soon, MM - cheers! (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 27th September 2024 - 10:04 AM |
