Gauge testing ?, need to know if I'am doing it right. |
porschetub |
Jun 11 2023, 04:38 PM
Advanced Member Group: Members Posts: 4,725 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Have a 911 temp insert I'am fitting to a 914 fuel gauge,I have 2 inserts but only one works but connecting power and earth to battery,needle go's straight to full reading is that correct ?.
If thats correct I want to test with sender,presuming if I connect sender to "G" on the rear of the gauge and earth the body of sender before applying heat to it ?. This isn't going in my car as I have all the 911 gauges sorted in my "6" conversion but a good winter project inside with the heating on (IMG:style_emoticons/default/biggrin.gif) . TIA ,cheers. |
Root_Werks |
Jun 12 2023, 05:21 PM
Village Idiot Group: Members Posts: 8,425 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Sounds correct so far. I've known a few folks that put a temp sender in boiling water to check the gauge.
I haven't had a temp gauge ever partially go bad on me. It's always the sender that seems to fail. |
FlacaProductions |
Jun 12 2023, 06:58 PM
Senior Member Group: Members Posts: 1,739 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
I agree - I've done it just like that with a numbered gauge to confirm the sender.
porschetub |
Jun 13 2023, 01:39 PM
Sounds correct so far. I've known a few folks that put a temp sender in boiling water to check the gauge. I haven't had a temp gauge ever partially go bad on me. It's always the sender that seems to fail. Thanks ,I'am the most unlucky guy with old VDO gauges,so will see how I go . Stopped buying used 911 tacho's as have had 1 fail not including the silver dot that came with the car. Currently looking @ a change to the gauge driver in my original gauge ,module uses modern tech and solders in to the old board with becomes redundant after fitting,got it from Bob @ ashlocktech ,top guy to deal with. As far if I can tell this temp gauge will pin out to max with power and ground connected but when the sender is in the system it should return to zero then rise when heat is applied..... hopefully. |
Morrie |
Jun 16 2023, 09:44 AM
Member Group: Members Posts: 181 Joined: 8-October 07 From: Cedar Park, Texas Member No.: 8,198 Region Association: Southwest Region |
Hey guys,
That looks like the housing for a 68-69 912 gauge. (Posts on the back?) If that is the source then be aware that the original gauges for these do not operate the same way as a 911 dual gauge would from the 70s and later. These early gauges require a special (read "expensive") sender as the original sender is NLA. They operate "opposite" of the modern gauges, meaning when doing the open/shorted test to peg the meter left and right, the early gauges operate in the opposite direction. Just be aware to avoid frustration. Best, Morrie |
porschetub |
Jun 19 2023, 09:08 PM
Hey guys, That looks like the housing for a 68-69 912 gauge. (Posts on the back?) If that is the source then be aware that the original gauges for these do not operate the same way as a 911 dual gauge would from the 70s and later. These early gauges require a special (read "expensive") sender as the original sender is NLA. They operate "opposite" of the modern gauges, meaning when doing the open/shorted test to peg the meter left and right, the early gauges operate in the opposite direction. Just be aware to avoid frustration. Best, Morrie Sorry for the late reply,keen eyes and yes you are correct it had studs on the back and part number says you are correct on the origin also,this was just temp gauge and I only bought it for the glass face and bezel ring as the face is rusty ,darn it. Will take what you said on board,cheers. |
Lo-Fi Version | Time is now: 27th September 2024 - 11:43 AM |
