/6 CIS trunk mod question., Want to keep top storage. |
Series9 |
Oct 21 2005, 12:16 PM
Lesbians taste like chicken. Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
If you have, or have pictures of a /6 conversion using CIS and the rear trunk for top storage, I would like to see some pictures of the modification.
Liz wants both CIS and top storage and I would like to facilitate that for her. |
Ferg |
Oct 21 2005, 12:28 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
2.7 or 3.0?
If a 2.7 Check out the build threads of DougC he bought my 2.7. The PO to me had a interesting solution to the problem using audi and vw parts. DougC's thread with pics: http://www.914world.com/bbs2/index.php?act=...hl=engine&st=20 Ferg. |
Series9 |
Oct 21 2005, 12:37 PM
That helps. Thanks Mike. Actually, one 2.7 and maybe one 3.0..... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) |
Ferg |
Oct 21 2005, 12:42 PM
If a 3.0 they will fit too, barely. You have to shave down the ribs on the rubber CIS boot, and loose the engine latch.
Mountain Man's 3.0, last pic shows what I mean. http://members.rennlist.com/mountain914/ Ferg |
lapuwali |
Oct 21 2005, 12:47 PM
I only had to remove the lid latch. The trunk was unmolested. The ribs on the snorkel hit the mesh on the lid, but the lid could be closed completely (just), using hood pins to hold it down. This was a 2.4T, so it looks like ALL of the CIS setups will clear. No pics, I haven't owned the car since '99.
Series9 |
Oct 21 2005, 12:53 PM
'Barely' works for me. I would much rather not mod the rear firewall. Good. I think both can be talked into pins for the engine deck.
goose2 |
Oct 21 2005, 02:39 PM
Senior Member Group: Members Posts: 976 Joined: 30-March 05 From: Eugene, Oregon Member No.: 3,847 Region Association: Pacific Northwest |
you can move the latch if you don't like pins
lylegd |
Oct 22 2005, 09:33 AM
Newbie Group: Members Posts: 49 Joined: 19-August 04 From: Fort Collins, CO Member No.: 2,574 |
I have a 1976 911S 2.7 liter CIS motor in a 75 car. (original CIS system)
a) Redid the hose layout on the backside of the throttle body so that the hoses and fittings fit tightly against the backside of the throttle body. Also relocated the AAR valve and its hoses. (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Relocated the engine lid latch to the right side of car. c) Lowered the engine by 1.25 inches by adding spacers to the four motor mounts and modifyed the mounting of the rubber that seals the engine sheet metal to the body. d) So far there are no mods to the rear trunk so the top fits well while being stored in the trunk. This works well but it is still a VERY tight fit. I am thinking about adding an access trap door to the front edge of the trunk so that I can get to the backside of the CIS. I would use sheet metal cut from a dismantled 914 car body to make the trapdoor and then fasten it in place with sheet metal screws and a gasket. I now have the sheet metal trapdoor but haven't installed it. It is very difficult to reattach the rubber air boot and its two hose clamps with the engine in the car. The access door/panel would be it easier to do this task. Even if I go ahead with installing the door, the roof will still fit in the rear trunk. Lyle |
MoveQik |
Oct 24 2005, 08:20 AM
What size wheels can I fit? Group: Members Posts: 4,654 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
Bullshit. They'll never go for that. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Series9 |
Oct 24 2005, 05:41 PM
To whom it may concern, 3.2 with Motronic solves everything..... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) |
MoveQik |
Oct 24 2005, 06:13 PM
Subtle as a sledgehammer. |
sixnotfour |
Oct 24 2005, 06:41 PM
914 Wizard Group: Members Posts: 10,525 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
2.7 vs 3.2 vs 3.6 just takes more $$ , Its all about the budget
seanery |
Oct 24 2005, 06:44 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
bluecar had a 2.7 cis for a short while, and we modded' the trunk edge a bit. It's still altered, but now it's got a 2.7 RS (sans MFI) in it. (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif)
John |
Oct 25 2005, 12:14 AM
The stock air cleaner in the stock location won't quite fit without cutting or moving some things around. The air flow meter is where the engine lid latch is. |
MoveQik |
Oct 25 2005, 07:53 AM
I seem to recall that Ferg's car had no latch on the lid for that reason. |
xitspd |
Oct 25 2005, 08:05 AM
Technology and Tradition 3.6 and 914-6 Group: Members Posts: 1,305 Joined: 17-November 04 From: Foothills of Mt. San Jacinto, CA Member No.: 3,136 |
(IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) Joe,
There was a Black 914-6 with a 3.0 in it at the D&G swap meet. It fit well with the CIS air box shaved a bit. Call John (VegasRacer) he has a 3.0 CSI in his machine. I am sure he has some good intell for you. Dan |
Series9 |
Oct 25 2005, 08:16 AM
Vegas Racer has a major mod to his rear firewall which precludes him from storing his top in the back.
It's no problem to move a few things on the 3.2 and keep the body stock. |
Ferg |
Oct 25 2005, 08:29 AM
Well, Sorta. My Latch was still there, and A 3.2 will fit without removing it. I removed the lid part of the latch, cause it was ever so slightly rubbing on the air flow sensor. All it would take is some shaving grinding of the retaining nut on the lid to be in the clear. Joe, If your now needing 3.2 pics, pm me and I will send you some of the custom bracket that was made to hold the air flow sensor, and the part number of the only air filter to fit without monkeying with downward facing tubing ect. Ferg. |
Series9 |
Oct 25 2005, 09:03 AM
OK, show me.
Ferg |
Oct 25 2005, 09:29 AM
Mount Close up
Attached image(s) |
Lo-Fi Version | Time is now: 27th September 2024 - 06:53 AM |
