V8 Conversion CLutch Bolt Torque Value, V8 Conversion CLutch Bolt Torque Value |
nick mironov |
Nov 30 2005, 01:56 AM
nickm Group: Members Posts: 204 Joined: 12-June 05 From: San Francisco, CA Member No.: 4,264 |
For a V8 conversion:
What is the proper torque wrench setting for bolting the clutch to the flywheel? The clutch is a 9" KEP. I came from Renegade. The Renegade website does not provide any torque setting information for the clutch bolts. |
neo914-6 |
Nov 30 2005, 02:51 AM
neo life Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
Nick,
I'm "pretty" sure it's 25 ft lbs. |
nick mironov |
Nov 30 2005, 12:41 PM
I called KEP. They said 22 ft-lb minimum up to a maximum of 30 ft-lb for a high-powered engine.
neo914-6 |
Nov 30 2005, 05:39 PM
found their email to me:
I thnk I'll use 27 ft lbs. Post some pics Nick! (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif) |
Crazyhippy |
Nov 30 2005, 07:16 PM
Insert witty comment here... Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None |
Renegade has a phone... Toll free even. (866) 498-2421
25-30ft lbs is the correct range. BJH |
bondo |
Nov 30 2005, 07:45 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
They're talking about the clutch to flywheel, not the flywheel to crank. |
Glenn.Payne |
Nov 30 2005, 07:49 PM
Newbie Group: Members Posts: 2 Joined: 30-November 05 From: Warrenton, VA Member No.: 5,211 |
Damn- I feel stupid. And my first post. I overlooked the word "clutch" and only saw "flywheel". I agree with the others @25-30 ftlb. for the clutch cover or pressure plate. Glenn
bondo |
Nov 30 2005, 08:00 PM
Hehe, at least you get to use the newbie excuse.. I make similar mistakes and I've been here for years! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Edit: Oh, and Welcome to the insanity! |
neo914-6 |
Nov 30 2005, 08:53 PM
Scott had Dana return my call 2 weeks later... (IMG:http://www.914world.com/bbs2/html/emoticons/av-943.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) Welcome Glen, whatcha got? (IMG:http://www.914world.com/bbs2/html/emoticons/wavey.gif) |
nick mironov |
Nov 30 2005, 09:01 PM
Word of caution about the torque values. Check the grade of the bolts you are using to make sure that they can take the desired torque. See attached table below. I think that the table is a bit conservative, as I have seen other tables with slightly higher values. The bolts are usually 8mm. The grade should be at least 10.9 and preferably 12.9 to handle anything 22 ft-lb or greater.
Attached image(s) |
Lo-Fi Version | Time is now: 27th September 2024 - 02:03 PM |
