New Bushings & Mounts, can't get R,2,4 now |
seanery |
Oct 10 2003, 03:19 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
(IMG:style_emoticons/default/confused24.gif) Cant get R,2,4.
1,3,5 are decent, but not exactly right. wtf? (IMG:style_emoticons/default/confused24.gif) |
Brad Roberts |
Oct 10 2003, 03:20 PM
You have the shifter set too far forward. Loosen it and pull the shifter back. This will give you the throw you need for R24.
B |
Brad Roberts |
Oct 10 2003, 03:21 PM
Loosen the clamp at the access hole. You acces it with a 13mm and a wrench on one side.
B |
seanery |
Oct 10 2003, 04:01 PM
I don't think it's that. I can't move the rod (by hand) into the R,2,4 gears.
It feels like it may be in a bind somewhere. |
Brad Roberts |
Pull the spacers out I installed in the bottom of the mounting for the shifter.
B |
seanery |
Oct 10 2003, 04:03 PM
I don't think that'll make a difference.
I was at the back of the car when I couldn't do it by hand, not at the shifter. |
seanery |
Oct 10 2003, 04:08 PM
the box is an 1/8 to 1/4 inch higher now, since the carrier was scrapped.
could this make the difference? |
seanery |
Oct 10 2003, 04:10 PM
this is the carrier not used:
(IMG:http://www.914world.com/bbs2/uploads/post-2-1065801716.jpg) |
ChrisReale |
Oct 10 2003, 04:22 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
Do you have the linkage installed correctly? Is is rubbing on a header/exchanger?
rhodyguy |
Oct 10 2003, 08:43 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
sean, iirc this is for a tailshifter. if ALL else fails remove the inspection cover at the very back of the trans, on the bottom. see if the rolled pin #11 p86 haynes securing the two levers is ok. #'s12 and 14 same page. i had a guy tell me i needed a new trany long ago. nope a 79 cent part. get a pan when you remove the cover gear lube is going to come out.
kevin |
Lo-Fi Version | Time is now: 27th September 2024 - 11:16 AM |
