Not so funny way to wake up, Damn that's cold |
DNHunt |
Oct 21 2003, 06:12 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Fool went out to the garage to get in a little work on the 914 before real work. Sprayed PB Blaster on a bunch of stuff in preparation for an engine drop Sat. Gonna do the cone screw at the tranny. Loosened and moved the black rubber cover and a cup of cold water dumped on my stomach. Shoulda stayed in bed. Hope the rest of the day isn't like that.
Dave |
rhodyguy |
Oct 21 2003, 06:15 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
dave, good morn. if it's split i have a couple in a box. you can have one.
kevin |
DNHunt |
Oct 21 2003, 06:24 AM
Kevin
Its in good shape. Thanks I'll give you a call sometime today. I could sure use a cheerleader Saturday if you are available. Gonna go take a shower. Only thing sicker than working on the car before work is sitting here checking out the board in a wet sweatshirt smelling like grease and PB Blaster. I'm hopeless. Dave |
rhodyguy |
Oct 21 2003, 06:38 AM
grease? you must be looking hard for it. i wonder how the water got in? the plan was to come over on sat. list; floor jack, dolly, the correct ratchet tool for the bolts on the cv's, the correct hex drive for the trans drain plugs (you can hold on to it for a while), a couple of old licience plates to help slide the fuel rails thru the engine shelve. how early do you want to start? we are both up while it's the middle of the night.
kevin |
JWest |
Oct 21 2003, 07:22 AM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
QUOTE(rhodyguy @ Oct 21 2003, 04:38 AM) a couple of old licience plates to help slide the fuel rails thru the engine shelve. Wanna esplain that one? (IMG:style_emoticons/default/huh.gif) |
rhodyguy |
Oct 21 2003, 07:26 AM
the fuel rails can get hung up on the shelve. i saw this method at triad. you slide the plate up between the rubber seal and the engine tin where the rails are, the plate acts as a guide and gently moves the rails inboard a bit. works real slick.
kevin |
JWest |
Oct 21 2003, 07:51 AM
I see... Cool!
Mark Henry |
Oct 21 2003, 07:59 AM
The new P-part for that cover comes with a pin hole at the lowest point to let the water drain out. If yours was full of water you might want to drill a hole in yours.
M |
Lo-Fi Version | Time is now: 27th September 2024 - 12:12 PM |
