Flat spot |
Flat spot |
ynotdd |
Oct 22 2003, 11:29 AM
Member Group: Members Posts: 156 Joined: 13-January 03 From: plainview, NY Member No.: 140 |
73 914 2.0 have a bad flat spot between 3000-3600 rpm replaced all regular stuff(position switch,MPS,checked timing).please help
r_towle |
Oct 22 2003, 11:38 AM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
if you have replaced the throttle positioning switch, try one of two things.
First, clean the throttle body inside and out. Two, test the accelerator cable for binding (could be in the tube, could be the peddle assembly. this occurs frequently and can be misdiagnosed as a flat spot. Rich |
r_towle |
Oct 22 2003, 11:39 AM
forgot one thing
The dizzy has old (30 year old) grease in between the advance plates (under the points) Take that apart and clean a re-grease that,,, when they get hot they have a tendancy to stick so you get no advance, or it might be tight in an advanced position. Rich |
Howard |
Oct 22 2003, 12:30 PM
Incontin(g)ent Member Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None |
Not exactly hi tech, but had same problem on my 2.0. Removed and cleaned injectors (compressed air 'back wash') and it went away.
Lo-Fi Version | Time is now: 27th September 2024 - 11:16 AM |
