Help to identify this MPS |
Mikey914 |
Dec 3 2006, 10:48 PM
The rubber man Group: Members Posts: 12,711 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Have a MPS that I thought was a 1.7. Tried to check it by swapping with my other, but the plug is different.
Is this a 1.8? Part numbers are 0280100049 & 022906051E Attached image(s) |
JeffBowlsby |
Dec 3 2006, 11:02 PM
914 Wiring Harnesses Group: Members Posts: 8,663 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
bd1308 |
Dec 4 2006, 02:34 AM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
plug was different?
Whats the other type? |
Mikey914 |
Dec 4 2006, 05:00 AM
type47 |
Dec 4 2006, 06:50 AM
i would bet that since the connections to the MPS are simply to two inductors (think of an inductor as simply a helix of wire like if you wound a wire around a pencil), that there is no polarity to have to pay attention to so the plug could go either way. some plugs have a little "stop" in the corners of the opening for the plug that restricts the plug from being connected wrong.
BMartin914 |
Dec 4 2006, 09:09 AM
||| Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
There are 4 numbers on the connector on the MPS and the same 4 numbers on the harness connector. The numbers correspond to one another - and it should only go in one way. It *may* not make a difference, but the same holds true throughout the car and some connectors do only fit in one fashion.
JeffBowlsby |
Dec 4 2006, 09:32 AM
Flip the connector, the MPS works the same either way.
Bleyseng |
Dec 4 2006, 09:54 AM
Aircooled Baby! Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Lo-Fi Version | Time is now: 27th September 2024 - 08:16 AM |
