2 liter metallurgy, Cylinder? |
newto914s |
Jan 22 2007, 07:03 PM
Senior Member Group: Members Posts: 561 Joined: 16-February 04 From: Thornton, CO Member No.: 1,663 |
I know that the original casts for the 2 liter cylinders are better than any new cylinders you can buy, Mahle, AA, aside from the LN Nikies of course. And if you got a set they are better to bore out to 96mm than buy new 96mm cylinders.
My question is are the cylinders from the 2 liter busses the same, and have the same benefits as the ones from the 2.0 914 motors? I know the pistons where different, I'm just concerned with the cylinders. I have a 79 bus core laying around here and I'm trying figure out if I part it, what I should keep from myself. Thanks guys |
SGB |
Jan 22 2007, 09:49 PM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
r_towle |
Jan 22 2007, 09:57 PM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I know that the original casts for the 2 liter cylinders are better than any new cylinders you can buy, Mahle, AA, aside from the LN Nikies of course. And if you got a set they are better to bore out to 96mm than buy new 96mm cylinders. My question is are the cylinders from the 2 liter busses the same, and have the same benefits as the ones from the 2.0 914 motors? I know the pistons where different, I'm just concerned with the cylinders. I have a 79 bus core laying around here and I'm trying figure out if I part it, what I should keep from myself. Thanks guys From what I have read, the only thing that is different between the two motors is the case, the pistons, and the heads. So, the cylinders should be the same parts. Rich |
Twystd1 |
Jan 22 2007, 10:02 PM
You don't want to know... really..... Group: Members Posts: 2,514 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 |
This is definetly popcorn smiley time.
I am gunna guess Jake will be right along in a day or so to tell us what he thinks. As he has posted his perception of this many times. Me personally, I would buy a matched set of cylinders, pistons, rings, and wrist pins from one supplier. That makes THEM liable for the appropriate bore machining, honing, piston and ring fit. I know that doesn't answer your question. I would use 914 cylinders with KBs like most of the guys use....... And buy em from Aircooled.net or Jake. C |
Lo-Fi Version | Time is now: 27th September 2024 - 11:49 AM |
