How do you disassemble a stock steering wheel?, part # 914 347 809 00? |
Johny Blackstain |
Feb 21 2007, 03:55 PM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
(IMG:style_emoticons/default/huh.gif) How does the stock steering wheel come apart? Bought one on eBay, read the thread about modifying a 4 to fit a 6, can't figure out how it comes apart. Specifically, removing the horn pad from the wheel, w/out damaging anything? Thanks. (IMG:style_emoticons/default/cool_shades.gif)
AZ914 |
Feb 21 2007, 03:59 PM
914 Dumbass Group: Members Posts: 1,461 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
I believe you can grab the wheel with your left hand, grap the horn pad with your right hand (or vice versa), and twist the horn pad counterclockwise while keeping the weel straight. The horn pad should twist about 1/8 turn, then pulls off. There should be a wire connecting the pad to the column (for the horn). Then there is a 22mm (I think) nut that holds the wheel to the shaft.
Johny Blackstain |
Feb 21 2007, 04:01 PM
I believe you can grab the wheel with your left hand, grap the horn pad with your right hand (or vice versa), and twist the horn pad counterclockwise while keeping the weel straight. The horn pad should twist about 1/8 turn, then pulls off. There should be a wire connecting the pad to the column (for the horn). Then there is a 22mm (I think) nut that holds the wheel to the shaft. (IMG:style_emoticons/default/beerchug.gif) Kick A**! Thanks you, it worked & the wire was already broken so no damage. Thank you. (IMG:style_emoticons/default/cool_shades.gif) |
TROJANMAN |
Looks nice in pictures......... Group: Members Posts: 5,275 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
i'm pretty sure it's a 27 mm nut.
i use an SAE 1 1/16 socket to take it off. guess i was late to the party (IMG:style_emoticons/default/biggrin.gif) This post has been edited by TROJANMAN: Feb 21 2007, 04:08 PM |
Aaron Cox |
i'm pretty sure it's a 27 mm nut. i use an SAE 1 1/16 socket to take it off. (IMG:style_emoticons/default/agree.gif) |
AZ914 |
Feb 21 2007, 04:10 PM
i'm pretty sure it's a 27 mm nut. i use an SAE 1 1/16 socket to take it off. (IMG:style_emoticons/default/agree.gif) Ya right... I used a 22mm once for somtin' (IMG:style_emoticons/default/biggrin.gif) |
Johny Blackstain |
Feb 21 2007, 04:13 PM
Fantastic... now does anyone have a 914-6 turn signal cancelling ring? It's missing from the Momo in the car now. I swear I must be the 47th owner of this car or something like that. Everything has been futzed with. Also, does anyone recognize this part number: 914 347 809 00?!! Book says 803 10 is rubber & 806 10 is leather. What did I buy? (IMG:style_emoticons/default/cool_shades.gif)
Dave_Darling |
Feb 21 2007, 07:36 PM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Johny Blackstain |
Feb 21 2007, 07:51 PM
... does anyone recognize this part number: 914 347 809 00?!! Mister PET says: (5) 914 347 809 00 STEERING WHEEL FOAM PART 1 It's on the "1972 and later" page. Sounds like a replacement?? Not sure. --DD I found it, thank you. Makes no sense... stamped on the inside, on the actual hub. Steering wheel is leather, not foam or rubber. Could definitely use a rebuid. Are the parts available... leather cover, rubber cap, cork washers, rubber gromets, etc... ? Thanks. (IMG:style_emoticons/default/cool_shades.gif) |
burton73 |
Feb 21 2007, 09:44 PM
burton73 Group: Members Posts: 3,655 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Alan Gun Leather Co. in Florida does the rebuilding of factory wheel like new. I called them and they said the leather would be $207. . I send the wheel to them
http://www.aglausa.com/p/home.html Bob |
Johny Blackstain |
Feb 22 2007, 06:48 AM
Alan Gun Leather Co. in Florida does the rebuilding of factory wheel like new. I called them and they said the leather would be $207. . I send the wheel to them http://www.aglausa.com/p/home.html Bob Thanks for the tip Bob. (IMG:style_emoticons/default/beerchug.gif) It looks like they recover leather & but nothing about replacing "innards". I'll call them today & find out. (IMG:style_emoticons/default/cool_shades.gif) |
burton73 |
Feb 22 2007, 08:49 PM
These are on ebay all the time. Porsche 356 911 912 914 VDM Steering wheel restore kit. Item number: 320083816089 There is a spring horn pin. Look at it.$45. or so
Bob |
Eric_Shea |
Feb 22 2007, 09:13 PM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE Ya right... I used a 22mm once for somtin' That was for your rear control arms... remember? (IMG:style_emoticons/default/wink.gif) |
Johny Blackstain |
Feb 22 2007, 09:23 PM
These are on ebay all the time. Porsche 356 911 912 914 VDM Steering wheel restore kit. Item number: 320083816089 There is a spring horn pin. Look at it.$45. or so Bob Thanks again, as usual. I'll wait for the next time he sells a kit. The one on now has 3 bids on it & is up to $32.00! (IMG:style_emoticons/default/laugh.gif) I think I bought my PET from that guy. Have to concentrate on getting a garage w/ a house attached to it. Spending too much time (IMG:style_emoticons/default/idea.gif) of 914's & not enough on finding a home. (IMG:style_emoticons/default/cool_shades.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 11:31 AM |
