strange front end noise ... |
SirAndy |
Jul 15 2007, 06:00 PM
Resident German Group: Admin Posts: 41,815 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
so
- i checked the wheel bearings, they're OK - i checked the calipers for sticky pistons, they're OK - i checked for tire rubbing, they're NOT i'm at a loss. when i drive, even slowly, no noise at all. but as soon as i have the wheels in full lock to the right, i hear a noise from the drivers side front that very much sounds like a sticky brake piston making the pads rub on the rotor. only on full lock (like getting in/out of a parking space) as soon as i straighten out the wheels just a bit, it goes away. why would a brake pad hit the rotor only on full lock ??? (IMG:style_emoticons/default/confused24.gif) Andy |
Brando |
Jul 15 2007, 06:03 PM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
Maybe you've got a wheel rubbing on the strut?
The sound you are hearing couldn't be a brake pad... Similar yes (metal on metal grinding?). Check for abrasive wear on your swaybar parts, the strut... Can't recall if you've got front coil-overs or not... |
JPB |
Jul 15 2007, 06:38 PM
The Crimson Rocket smiles in your general direction. Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
The opposite side bearing being pulled? (IMG:style_emoticons/default/beer.gif)
914Mike |
Jul 15 2007, 11:40 PM
Member Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 |
so - i checked the wheel bearings, they're OK - i checked the calipers for sticky pistons, they're OK - i checked for tire rubbing, they're NOT (IMG:style_emoticons/default/confused24.gif) Andy I just found a loose nut, the one that holds the shock into the strut. Definately made strange noises while turning... |
Lo-Fi Version | Time is now: 27th September 2024 - 01:18 PM |
