Hydraulic Clutch, This works GREAT! |
PRS914-6 |
Sep 1 2007, 10:29 PM
Excellence Magazine Project 914 3.6 Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
Seems like there is always interest in converting to a hydraulic clutch. Using a 911 clutch gives a bit of a stiff pedal but my biggest complaint was I didn't like the modulation and feel especially using a performance clutch disk. The 914-6 cable is much smaller in diameter than a 911 cable and aggravates the problem. In addition, my first gear is really tall and with a clutch that felt like it was on/off was a little annoying and down right scary when stopped on a hill with someone on my ass.
I picked up a new generic master cylinder and pull style slave (available at most any buggy shop for under $150.00 I also picked up a 4 ounce remote reservoir. I made a plate that fit under the brake master cylinder and a bracket that fit on the side cover of my 915 tranny and ran the hydraulic lines down the tunnel. I also installed a bracket from the plate to the I beam of the suspension to eliminate any flex. I'll cover the entire installation in a future issue of Excellence with the project car (at Pete's discretion) but here are a few pictures to show the method I used. The "feel" and modulation of the clutch is dramatically improved. Absolutely smooth as silk now. |
PRS914-6 |
Sep 1 2007, 10:33 PM
And a few more......
And Ron S. This is for you..... |
brp914 |
Sep 1 2007, 10:58 PM
Unregistered |
(IMG:style_emoticons/default/thumb3d.gif) That is something to be proud of. BTW, how are you shifting that 915? WEVO? Or did you do something wild there too? If WEVO, how do you like it?
PRS914-6 |
Sep 1 2007, 11:05 PM
WEVO. I like it a lot. It shifts better and more precise than my 911 (but takes a tad more effort)
76-914 |
Feb 21 2013, 10:00 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,634 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I know, I know. 3 demerits for bringing an old thread back to life but..........Paul would you mind posting some more on this. I wasn't around here then and don't have the Excellence article to peruse. TIA, kent
KaptKaos |
Feb 21 2013, 01:33 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
It is me or does that master cylinder seem to be in the right most (throttle) position?
EDIT - NVM - I see it's being actuated by the clutch pedal. |
URY914 |
Feb 21 2013, 01:41 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 123,936 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
The clutch pedal is on a shaft that passes thru the brake pedel base.
I'd like to see an update to this as well. |
biosurfer1 |
Feb 21 2013, 02:56 PM
Teener fo Life! Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
I'm sure Paul will be along shortly but I've had the pleasure of testing this out in person and it really is a big difference and would make stop and go traffic a LOT more manageable.
0396 |
Feb 21 2013, 04:56 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
If Paul would offer "kit" I'm in....
PRS914-6 |
Feb 21 2013, 05:11 PM
Here are a few pics that should help. You simply make a plate with 90 deg flange that goes under the brake mounting holes and extend it over to mount the clutch. Make a brace to the I beam. There is not much pressure for the clutch so it doesn't take a lot.
The pedal rod gets flipped forward and you will need to adjust length FYI....it does not make it easier since it is a 1:1 ratio on cylinders. It does however make it MUCH smoother |
RonW |
Feb 21 2013, 05:14 PM
Member Group: Members Posts: 76 Joined: 31-December 05 From: Alameda, CA Member No.: 5,340 Region Association: Northern California |
nicely done. subscribed.
RON S. |
Feb 21 2013, 05:34 PM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
Paul, Welcome to the hydraulic world... (IMG:style_emoticons/default/biggrin.gif) I've had quite a few years of driving on mine, and it's always been a smooth linear motion. You'll quickly get used to the nicer feel. No looking back now Cheers (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/beer.gif) |
racerx9146 |
Feb 21 2013, 07:40 PM
good design never goes out of date.. Group: Members Posts: 174 Joined: 1-January 04 From: Sacramento, CA Member No.: 1,483 Region Association: Northern California |
Larry hubby did a nice write up back in 2008 with some nice detailed diagrams using 944 factory parts. Halfway down this thread
http://www.914world.com/bbs2/index.php?sho...c=90342&hl= I am following Larry's example using the longer 911 clutch shaft and a bell crank at the transmission side to allow use of the 944 slave. I did not create the nice aluminium shim Larry did due to my lack of machining skills but did a flat plate like Paul S. The thicker plate also between cluster and brake move the master away from the cluster by 1/4" but you can make it up with adjustment on the rod. I also shim my brake, clutch pedals down a little bit to give my self more legroom. Created a brace at the same time. I also created a splitter down at the brake to share the rear fluid supply with clutch slave so I don't need an extra reservoir for the clutch. I have not done the rear but my front looks like this, similar to Paul S. Hardest part is running the hard line through the tunnel and back to transaxle cleanly. Daron My master setup. I think this is Larry's slave setup. Could not find original post on this pic... |
GeorgeRud |
Feb 22 2013, 05:47 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Any info on the size of the master or slave cylinders used for the clutch hydraulics? Was the positioning of the clutch pedal arm changed from stock? I can't quite understand what was changed, but certainly like the concept.
A bolt together kit would be nice! |
IronHillRestorations |
Feb 24 2013, 09:20 PM
I. I. R. C. Group: Members Posts: 6,775 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
In '95 I used a 928 clutch master cylinder and put a Y in the brake fluid line to supply it, and a CNC pull slave cylinder.
PRS914-6 |
Feb 24 2013, 09:36 PM
The sizes of the master and slave should be the same. That gives a 1:1 ratio just like the cable. 3/4 is an easy size to get. Look at buggy shop/sand rail/dunebuggy web sites. The entire hydraulic setup was only about $150.00 new and their generic design makes them easy and cheap to install and/or replace
It should be noted that you can get pull or push style slaves so you don't have to use a bell-crank. I used a pull style. |
76-914 |
Feb 24 2013, 10:01 PM
Paul, this is a great help. Thx again.
dfelz |
Feb 24 2013, 10:57 PM
beach bum Group: Members Posts: 419 Joined: 7-June 12 From: San Diego Member No.: 14,538 Region Association: Southern California |
Hey Paul, whats the bore diam. of the master cylinder you used?
And what is the "WEVO" thing referenced a few times in the thread?? Thanks! |
Dave_Darling |
Feb 25 2013, 10:18 AM
914 Idiot Group: Members Posts: 15,060 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The exact diameter is not very important, just that the master and slave diameters should match. As he said, 3/4" is easy to get ahold of and use.
WEVO is Windrush Evolutions, and they make (among other things) a shifter base that Paul is using. --DD |
euro911 |
Feb 25 2013, 01:11 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,858 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Lo-Fi Version | Time is now: 23rd November 2024 - 04:33 AM |
