Wevo 915 trans mod, Linkage questions?? |
East coaster |
Dec 22 2003, 12:48 PM
Senior Member Group: Members Posts: 1,752 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None |
Ok........if you go with a 915 trans w/Wevo mod. What goodies are "required" to create a linkage and what goodies are "desired"??
If at this end there's a Wevo mod'd 915................................this end is a stock 911 shift lever. Fill in the dots (shift rods/bushings/couplers/etc..). |
Brad Roberts |
Dec 22 2003, 01:23 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
What year is the tub ??
B |
East coaster |
Dec 22 2003, 01:59 PM
'74 tub and since your reading...........what about axles??
Brad Roberts |
Dec 22 2003, 02:17 PM
911 shifter to early shift rod necked down for the late firewall bushing and then a WEVO coupler... then a straight rod to another WEVO coupler at the tranny.
A WEVO coupler is only needed at the tranny. To do this on the cheap: Find a stock 915 shifter/early 914 shift rod/sacrifice a late 914 shift rod and weld the two together I can show you in pics soon. The Axles. I need to measure a set of 911SC axles and see what the difference is... this is the cheapest easiest route if the length is correct. We run the larger early 911 drive flanges in the tranny and at the control arm with stock early 911 axles. The SC drive flanges come stock in the 915 trannys (late boxes and they slip right into 9146/early 911 drive hubs in the control arms. B |
BravoHotel |
Dec 23 2003, 10:05 AM
Member Group: Members Posts: 153 Joined: 5-March 03 From: Columbus, MS Member No.: 399 |
Brad, can you give us the cost issues and parts collecting issues and fabrication issues on doing the Wevo 915 conversion?
Can you lay out the differences in the "on the cheap" version vs. "wish list" version Thanks BH PS: PICS? |
Brad Roberts |
Dec 23 2003, 10:40 AM
I can.... and need too, but it will be sometime over this Christmas holiday that I get a chance to do it.
Just bump this Thursday or Friday. B |
BravoHotel |
Dec 23 2003, 12:51 PM
no problemo.
PorschePony |
Jan 20 2004, 05:14 PM
NorthROLLERcoaster Group: Members Posts: 106 Joined: 23-January 03 From: Northcoast, Ohio Member No.: 187 |
Brad, have you put that list together yet? I have been watching myself for the how-to's and don'ts. I have a 915 and was wondering what is involved in the merger of the 915 into a 901 area......
Are there any articles dedicated to what all needs done to thte tranny and surrounding connections that people like me can look at? ed |
Brad Roberts |
Jan 22 2004, 04:54 PM
I am slammed with work. I'll have to revisit this later. I barely have time to check in right now or answer email.
B |
Lo-Fi Version | Time is now: 27th September 2024 - 10:15 AM |
