Need help with vacuum lines for 1.8, to the vacuum advance on the dizzy |
Cevan |
Jan 31 2008, 08:49 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
I have a '75 1.8 L-Jet with a 048 distributor. Despite taking numerous photos prior to disassembly, I can't figure out where one of the two vacuum lines from the distributor goes. The Pelican diagram shows them both going to the throttle body. The red line in the picture below is the 5mm ID line. Where does the line go from the green circled area. This is a smaller diameter line (4mm according to PP).
Dave_Darling |
Jan 31 2008, 10:41 PM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
It goes to the other side of the throttle body. If there is no fitting on the other side of the throttle body, leave it unconnected. Or do what the factory did, which is hook a hose up to it and tuck the other end of the hose (unplugged!) down under the manifold.
--DD |
Cevan |
Feb 1 2008, 06:35 AM
Dave, thanks for the reply. There was a short piece of hose connected to it (maybe 5 inches) but I couldn't find anywhere to hook it up to. That explains it.
ClayPerrine |
Feb 1 2008, 10:44 AM
Life's been good to me so far..... Group: Admin Posts: 15,820 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
One word of caution...
If you take it in for a state inspection, some tire monkey doing inspections will see the vacuum port that doesn't have anything connected and try to fail you for it. He will say that you have to have all of the vacuum lines hooked up to pass.... BTDT So...avoid the stupid tire monkeys... hook a line up to it and tuck it under the intake plenum. |
Cevan |
Feb 1 2008, 01:01 PM
One word of caution... If you take it in for a state inspection, some tire monkey doing inspections will see the vacuum port that doesn't have anything connected and try to fail you for it. He will say that you have to have all of the vacuum lines hooked up to pass.... BTDT So...avoid the stupid tire monkeys... hook a line up to it and tuck it under the intake plenum. It appears from the photos I took, that's the way it was done. I'll keep it the same way. |
Lo-Fi Version | Time is now: 27th September 2024 - 08:00 AM |
