Rear Brakes, Inner Adjuster Came Out |
jgara962 |
Feb 24 2008, 02:09 PM
Yo, this is how I roll Group: Members Posts: 823 Joined: 5-April 05 From: Napa, CA Member No.: 3,879 Region Association: Northern California |
I'm taking my rear brake pads out which I had done and was in the process of pushing back the pistons while turning the adjusters. I guess I turned the inner one a little too much because it came all the way out which I discovered when I removed the hex and the adjuster was still attached. Problem, or do I just put it back in?
Also, I'm using a flat piece of metal to press back the pistons, but they don't seem to want to go back all of the way. Any tips? I'm afraid to keep pressing on them and damaging something. |
McMark |
Feb 24 2008, 02:21 PM
The rear adjuster comes out. Nothing holds it in. No problem there.
The rear inner pistons must be 'pushed' back by using the adjuster. You can just force them back. Slide the adjuster back into place and turn it like you are 'unscrewing' it (counter-clockwise). That will drag the piston back into the caliper. If the piston is sticky, you might have to press on it as well as turn the adjuster. Also watch your brake fluid level in the reservoir, because retracting the pistons will displace fluid and you can overflow. |
jgara962 |
Feb 24 2008, 02:50 PM
The rear adjuster comes out. Nothing holds it in. No problem there. The rear inner pistons must be 'pushed' back by using the adjuster. You can just force them back. Slide the adjuster back into place and turn it like you are 'unscrewing' it (counter-clockwise). That will drag the piston back into the caliper. If the piston is sticky, you might have to press on it as well as turn the adjuster. Also watch your brake fluid level in the reservoir, because retracting the pistons will displace fluid and you can overflow. I'm unscrewing it and pushing, but it doesn't seem to want to go back any further? Maybe it's time to just show it who's boss! (IMG:style_emoticons/default/biggrin.gif) |
McMark |
Feb 24 2008, 02:58 PM
The mechanism that the adjuster screws into (think nut) is only held into the caliper piston by spring tension. If the piston gets stuck, it is possible to accidentally pop the mechanism out of the piston. If that were the case you could have unscrewed the mechanism down flush to the caliper body. If the adjuster stops turning, don't force it. If the mechanism did pop out, that means that the piston is free to move and simply using force should retract it more. And finally, the mechanism can be popped back into place by holding the piston firm and screwing in the adjuster until it pops back in.
Check the classic threads area for some documents on rebuild rear calipers as well as images of caliper parts. (IMG:style_emoticons/default/wink.gif) |
McMark |
Feb 24 2008, 02:59 PM
Are you using a c-clamp to press the piston?
jgara962 |
Feb 24 2008, 03:09 PM
davep |
Feb 24 2008, 04:09 PM
914 Historian Group: Benefactors Posts: 5,195 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
It just shows you don't know what you are doing. You should look up previous threads on how these are rebuilt so you can understand how everything functions. If you have to force it, then there is something very wrong. |
jgara962 |
Feb 24 2008, 04:14 PM
It just shows you don't know what you are doing. You should look up previous threads on how these are rebuilt so you can understand how everything functions. If you have to force it, then there is something very wrong. It was a joke - note the smiley face. It's handled (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 06:40 AM |
