gasket for oil pump |
DarrenG |
Jul 16 2008, 09:37 AM
Newbie Group: Members Posts: 46 Joined: 20-May 08 From: Liberty, MO Member No.: 9,078 Region Association: Upper MidWest |
Does anyone know if coppercoat can be used instead of a gasket when installing the oil pump?
Thanks D |
Cap'n Krusty |
Jul 16 2008, 09:50 AM
Why? You "going paperless"? The Cap'n
DarrenG |
Jul 16 2008, 10:29 AM
dbgriffith75 |
Jul 16 2008, 10:50 AM
TheGrif Group: Members Posts: 509 Joined: 25-July 07 From: Iowa, USA Member No.: 7,945 Region Association: Upper MidWest |
I'm not sure what "coppercoat" is, but if it's similar to high temp goop, you should be OK. The oil pump fits pretty snugly into the crankcase and there's not much room for oil to leak out. As long as you give it proper time (I think 8 hours is reccommended, but I always give it 24) to set up and seal, it shouldn't be a problem.
DarrenG |
Jul 16 2008, 10:57 AM
I'm not sure what "coppercoat" is, but if it's similar to high temp goop, you should be OK. The oil pump fits pretty snugly into the crankcase and there's not much room for oil to leak out. As long as you give it proper time (I think 8 hours is reccommended, but I always give it 24) to set up and seal, it shouldn't be a problem. It's high temp goop with copper flakes in it to fill small imperfections. really messy. I'll run with it. Thanks |
McMark |
Jul 17 2008, 12:33 AM
Loctite 518 (the red stuff) is great with the pressures involved. I learned the hard way, and I won't use anything else now.
Lo-Fi Version | Time is now: 27th September 2024 - 12:47 PM |
