Full Flow engine mount? |
finstermojo |
Aug 17 2008, 08:39 AM
Newbie Group: Members Posts: 40 Joined: 10-November 07 From: new york Member No.: 8,314 |
I am finishing my Rabys 2316 and working on the full flow oil system and the line off the oil pump cover will need me to notch the engine mount out and install a 45 degree elbow so it can get out from the front. Has anybody else removed material off the mount so the fitting will fit. I attached the picture so you can see what i am talking about has anybody else had to deal with this? I also a included a pict of the entire engine with a single wire chevy 100 amp alternater installed.
Attached thumbnail(s) |
McMark |
Aug 17 2008, 10:30 AM
Yup, remove the metal on the inside brace, leave the outside brace. I don't have any pictures here at home.
ConeDodger |
Aug 17 2008, 11:53 AM
Apex killer! Group: Members Posts: 23,758 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Paul Sayegh used one of his machine shop tools to remove an arc of material large enough to allow the fitting to clear. I underestimated when I told him how much so it still had to be attacked with a bench grinder when I got home, but yes it now fits... Sorry no pictures here either...
Joe Ricard |
Aug 17 2008, 01:16 PM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Yep I cut my mount on both side of the mount.
I had this modification on my 2098cc and autocrossing the piss out of it for a year now. Also using hard plastic mounts on the engine bar. Didn't use a 45 angle for the hose. Just a straight AN10 fitting and the hose curves around and then rides up above the valve cover bail to a braket mounted to the under side of the rear trunk. |
URY914 |
Aug 17 2008, 01:27 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 123,027 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
This is what I did...
Attached image(s) |
URY914 |
Aug 17 2008, 01:29 PM
with pipe nipple...
Attached image(s) |
finstermojo |
Aug 17 2008, 03:55 PM
Mark Henry |
Aug 17 2008, 07:40 PM
I did sell a modified mount but It took longer to make than it's worth.
Pretty sure it's still in the vendors section, take a look and make a copy. I don't like a nipple because I've seen them break (more than once) and wipe out an engine. To me a "brace" will just add even more stress to a nipple. |
URY914 |
Aug 17 2008, 08:17 PM
I used the shortest nipple I could. If it was shorter the AN connection would be too close and would interfere with the engine mount.
Mark Henry |
Aug 17 2008, 08:26 PM
Yep...don't like those fittings as well....or the aluminum pump cover.....just IMHO
Jake Raby |
Aug 17 2008, 09:19 PM
Engine Surgeon Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
I don't like rigid tubing either...
The removal of mount material is no big deal and we haven't seen any weakness result from it. I am realigning all my oil pump kits and all future kits for the 914 will now have the mounts included with them. Mark, I now have a tool steel intermediate plate for the aluminum oil pump covers to eliminate wear. These have been RAT products for over a year now. |
Mark Henry |
Aug 18 2008, 09:59 AM
Yep I've never used anything but steel covers, one look at an old used stock T1 cover and you'll know why I feel this way.
Jake's solution is cool and one might be able to use a Al cover that has a nickies coated side, but that would be spendy. My mounts had 2 gussets welded into the backside, never had issues as well. |
Jake Raby |
Aug 18 2008, 08:06 PM
Matt, what happened to the manifolds we shipped with the heads?? The Pierce manifolds you picture are good for a solid 6% reduction in flow and that equates to a solid 10HP or MORE on that engine, plus they were match ported to the heads..
leave things as we Engineered them, else you'll never get the output of efficiency from the kit. Everything we provide is included for a reason. |
r_towle |
Aug 18 2008, 09:48 PM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Matt, what happened to the manifolds we shipped with the heads?? The Pierce manifolds you picture are good for a solid 6% reduction in flow and that equates to a solid 10HP or MORE on that engine, plus they were match ported to the heads.. leave things as we Engineered them, else you'll never get the output of efficiency from the kit. Everything we provide is included for a reason. Did you provide the valve covers? If so, are they leak proof??????????????????????? Not that I would LOVE a leak proof and easy to remove valve cover...lol Rich |
finstermojo |
Aug 19 2008, 06:31 AM
The manifolds in the picture are the ones you included with the kit are they the wrong ones for the kit? i changed nothing.
The valve covers did not come with the kit. they are the same ones i used on my other engine and they did not leak at all i think they are made by CB Performance. Every body who sees them says the same thing about them leaking but they dont and they also help quite some of the valve train noice. I cleaned them up and also painted them. |
Mark Henry |
Aug 19 2008, 07:19 AM
Jake just an FYI, the manifolds you included in the set of heads you sent me wouldn't fit on a 356 classic kitcar.
finstermojo in reply to your PM it's in the member vendors section: http://www.914world.com/bbs2/index.php?showtopic=11164 Not the greatest pic for copying but all you can't see is 2 small gussets on the backside of the mount, |
Jake Raby |
Aug 19 2008, 10:21 AM
QUOTE The manifolds in the picture are the ones you included with the kit are they the wrong ones for the kit? i changed nothing QUOTE The manifolds in the picture are the ones you included with the kit are they the wrong ones for the kit? i changed nothing OK.. So, they were match ported to the heads and came with the kit, cool...That means Len has overcome their typical constraints.. Good to go. mark, We provide many engines for the guys at Beck and have dozens of engines in CMC, Beck and Vintage Speedsters and have never had any issues with the manifolds fitting those cars.. What kit was this car? why wouldn't they fit? These are the things I need to know. |
Lo-Fi Version | Time is now: 27th September 2024 - 05:11 AM |
