Wiper Park problems, not parking properly |
mpissaquah |
Aug 31 2008, 01:35 PM
Mike P Group: Members Posts: 31 Joined: 24-September 05 From: Sammamish, WA Member No.: 4,857 Region Association: None |
When turning my wipers off they do not park in the normal position. Instead of parking in the lower left side of the windshield, they swing back up a bit and park a in an annoying position in front of the field of visions. ie: park position takes the wipers back up the right a bit instead of placing them all the way down to the left. It's as if something is reversed for parking and instead of going all the way down and to the left, they go back up a bit to the right. It appears everything is wired correctly.
See picture for where they park currently. I've searched the discussions and cant seem to find any answers. so I turn to the wise members for help |
904svo |
Aug 31 2008, 02:50 PM
904SVO Group: Members Posts: 1,124 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
Off hand I would say its time for a new wipermotor,or you have a bad electrical
connection on the wiper motor. The stop postion is controlled on the wiper motor thru a cam. |
mpissaquah |
Aug 31 2008, 04:06 PM
Off hand I would say its time for a new wipermotor,or you have a bad electrical connection on the wiper motor. The stop postion is controlled on the wiper motor thru a cam. The wiper motor is new...... it moves to a "park" setting, its jsut back to teh right instead of to the far left. |
904svo |
Aug 31 2008, 06:12 PM
Off hand I would say its time for a new wipermotor,or you have a bad electrical connection on the wiper motor. The stop postion is controlled on the wiper motor thru a cam. The wiper motor is new...... it moves to a "park" setting, its jsut back to teh right instead of to the far left. Then readjust the wiper arm to where you want it. |
Spoke |
Aug 31 2008, 08:20 PM
Jerry Group: Members Posts: 7,052 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Instead of parking in the lower left side of the windshield, they swing back up a bit and park a in an annoying position in front of the field of visions. It sounds like the arm attachment to the motor is off. If the wipers stop at the same place every time, the arm assembly attached to the motor is off. Had a similar issue with a headlight motor. In the up position, the headlight was not pointed up enough. Realized that the arm to the motor was misaligned such that the headlight would go up ok, but park just after the full up position. |
orange914 |
Aug 31 2008, 09:00 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
Instead of parking in the lower left side of the windshield, they swing back up a bit and park a in an annoying position in front of the field of visions. It sounds like the arm attachment to the motor is off. If the wipers stop at the same place every time, the arm assembly attached to the motor is off. i think spoke is saying the wipers are in the right position (going left to right in the right pattern), it just keeps going and parking later than where it should... no??? mike |
mpissaquah |
Aug 31 2008, 10:06 PM
Instead of parking in the lower left side of the windshield, they swing back up a bit and park a in an annoying position in front of the field of visions. It sounds like the arm attachment to the motor is off. If the wipers stop at the same place every time, the arm assembly attached to the motor is off. i think spoke is saying the wipers are in the right position (going left to right in the right pattern), it just keeps going and parking later than where it should... no??? mike It does not seem like a motor attachemnt issue. When I turn the wipers off they continue thier motion, then swing bakc all the way to the left, then finaly (park) back up to the the right about 4-5 inches, instead of all the way to the left. It seems they should park furhter left (down) than they do while operating. |
Spoke |
Sep 1 2008, 08:16 AM
The wipers should park at the lowest travel of the arms. Since the electrical contacts for motor travel are in the motor assembly, there is no way to adjust the motor to change where the arms park.
The motor mechanism just goes around a circle and stops at one point. This stopping point should coincide with the arm assembly (not just the wiper arm but the whole moving assembly) being at their lowest position. If the motor assembly has splines, perhaps the arm assembly is off by one spline? On my 71, the wipers park in the extreme right position so the arm assembly has been connected to the motor exactly 180 degrees off from normal where the wipers park on the left side. |
Eric_Shea |
Sep 1 2008, 06:31 PM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE If the motor assembly has splines, perhaps the arm assembly is off by one spline? Ding, ding, ding, ding, ding, ding, ding, ding, ding... |
mpissaquah |
Sep 22 2008, 11:47 PM
This all makes sence except that it does not appear to be how mine is performing. They park about 1/3rd of the way between the far left travel and far right travel and ned up near the middle fo the windshield.
The wipers should park at the lowest travel of the arms. Since the electrical contacts for motor travel are in the motor assembly, there is no way to adjust the motor to change where the arms park. The motor mechanism just goes around a circle and stops at one point. This stopping point should coincide with the arm assembly (not just the wiper arm but the whole moving assembly) being at their lowest position. If the motor assembly has splines, perhaps the arm assembly is off by one spline? On my 71, the wipers park in the extreme right position so the arm assembly has been connected to the motor exactly 180 degrees off from normal where the wipers park on the left side. |
zambezi |
Sep 23 2008, 09:05 AM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
This all makes sence except that it does not appear to be how mine is performing. They park about 1/3rd of the way between the far left travel and far right travel and ned up near the middle fo the windshield. The wipers should park at the lowest travel of the arms. Since the electrical contacts for motor travel are in the motor assembly, there is no way to adjust the motor to change where the arms park. The motor mechanism just goes around a circle and stops at one point. This stopping point should coincide with the arm assembly (not just the wiper arm but the whole moving assembly) being at their lowest position. If the motor assembly has splines, perhaps the arm assembly is off by one spline? On my 71, the wipers park in the extreme right position so the arm assembly has been connected to the motor exactly 180 degrees off from normal where the wipers park on the left side. JIM |
Bartlett 914 |
Sep 23 2008, 09:08 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
This all makes sence except that it does not appear to be how mine is performing. They park about 1/3rd of the way between the far left travel and far right travel and ned up near the middle fo the windshield. The wipers should park at the lowest travel of the arms. Since the electrical contacts for motor travel are in the motor assembly, there is no way to adjust the motor to change where the arms park. The motor mechanism just goes around a circle and stops at one point. This stopping point should coincide with the arm assembly (not just the wiper arm but the whole moving assembly) being at their lowest position. If the motor assembly has splines, perhaps the arm assembly is off by one spline? On my 71, the wipers park in the extreme right position so the arm assembly has been connected to the motor exactly 180 degrees off from normal where the wipers park on the left side. Mine do this a little. The suggestions about moving to a different spline won't fix the problem. This would make the wipers travel too far down towards the cowl when the wipers are on. I suspect my problem is a sloppy linkage. I think it is all too loose allowing the wipers coasts up more than it should. |
zambezi |
Sep 23 2008, 09:13 AM
This all makes sence except that it does not appear to be how mine is performing. They park about 1/3rd of the way between the far left travel and far right travel and ned up near the middle fo the windshield. The wipers should park at the lowest travel of the arms. Since the electrical contacts for motor travel are in the motor assembly, there is no way to adjust the motor to change where the arms park. The motor mechanism just goes around a circle and stops at one point. This stopping point should coincide with the arm assembly (not just the wiper arm but the whole moving assembly) being at their lowest position. If the motor assembly has splines, perhaps the arm assembly is off by one spline? On my 71, the wipers park in the extreme right position so the arm assembly has been connected to the motor exactly 180 degrees off from normal where the wipers park on the left side. Mine do this a little. The suggestions about moving to a different spline won't fix the problem. This would make the wipers travel too far down towards the cowl when the wipers are on. I suspect my problem is a sloppy linkage. I think it is all too loose allowing the wipers coasts up more than it should. You must move the spline of the arm at the motor not the spline of the wiper arm. The complete travel of the wipers left to right is designed in the lengths of the entire wiper mechanisms. To change the over all travel you would have to redesign the wiper linkages. If you disconnect the arm at the motor you can freely move the wipers left and right by hand and they should never be too low to the cowl unless you have them timed wrong at the splines at the wiper arms themselves. |
Dave_Darling |
Sep 23 2008, 09:38 AM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
It sounds like people are getting confused about the splines, here.
There are two sets of splines. One set is the obvious ones, where the wiper arms bolt on to the shafts that stick out through the cowl. The second set is where the wiper motor itself attaches to the linkage that the first set of splines are attached to. The second set is the one that is misaligned, changing where the wipers park. --DD |
Bartlett 914 |
Sep 23 2008, 10:00 AM
It sounds like people are getting confused about the splines, here. There are two sets of splines. One set is the obvious ones, where the wiper arms bolt on to the shafts that stick out through the cowl. The second set is where the wiper motor itself attaches to the linkage that the first set of splines are attached to. The second set is the one that is misaligned, changing where the wipers park. --DD (IMG:style_emoticons/default/pray.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 09:07 AM |
