> 3.0 carrera vs 3.0sc motors, dreaming out loud
pete-stevers
post Sep 25 2008, 07:53 PM
saved from fire!
I currently have a early3.0 sc motor in the Harlot
It is pretty crazy fast....
but i want more...eventually and when the pocket book says i can....oh yes and lets not forget my dear wife's blessing
so here are my thoughts....
I am able to pick up a 3.0 carerra
which i would eventually rebuild to a 3.0 or 3.2 ss
Or build the 3.0 sc out to a 3.4
i like the idea of a ss,
while the build up of the sc less costly (due to me already owning the motor)
but will need to be usable on the street
opinions and thoughts are welcome
Replies(1 - 19)
Cap'n Krusty
post Sep 25 2008, 08:03 PM
Cap'n Krusty
Since a 3 litre Carrera motor is essentially a 1976/77 version of the SC, a prototype if you will, of the '78-'83 SC motor, why bother? Sure it makes 15 more HP (that's not even 10%), but you're not gonna keep it stock anyway. Put the money in the buildup.
The Cap'n
post Sep 25 2008, 08:05 PM
Resident German
QUOTE(pete-stevers @ Sep 25 2008, 05:53 PM) *
Sell the 3.0L Motor and buy yourself a '95 3.6L Engine ...
(IMG:style_emoticons/default/shades.gif) Andy
messix
post Sep 25 2008, 08:46 PM
AKA "CLUTCH KILLER"!
From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada
build a bad ass 2.5!!!! (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/aktion035.gif)
sixnotfour
post Sep 25 2008, 09:26 PM
Does it have the 6 bolt or 9 bolt flywheel ?
Justinp71
post Sep 25 2008, 10:10 PM
I understood that all 3.0 and above are 9 bolt.
I agree with keeping your existing motor, you also know the history on it. I wouldn't see why a 3.4L wouldn't be streetable. Normally the more cc's the more streetable it is, b/c you don't have to go to radical on the cam to get power.
I have an '81 sc motor, carbs and DC 19 cams. And it kicks a$$. (IMG:style_emoticons/default/shades.gif)
But the 3.6's are pretty sweet and probably cheaper to run then rebuilding a 3.0, and they get awesome gas mileage.
Another note a 3.4 ss would be a better motor if you plan on keeping the 901 gearbox.
Good luck!
sixnotfour
post Sep 25 2008, 10:15 PM
early turbo and carrera have 6 bolt, highly desirable for really SS motor.
dw914er
post Sep 25 2008, 10:36 PM
Planning Cities
QUOTE(SirAndy @ Sep 25 2008, 07:05 PM) *
I'll take the 3.0 lol
seriously though, spend the money for the buildup, you'll save money and/or be able to get more power.
pete-stevers
post Sep 25 2008, 11:23 PM
saved from fire!
QUOTE(sixnotfour @ Sep 25 2008, 08:26 PM) *
i am 95 percent sure the motor has the six bolt crank....and has mfi
iamchappy
post Sep 25 2008, 11:25 PM
It all happens so fast!
Turbo it. Best bang for the buck and will outrun Andy's 3.6. (IMG:style_emoticons/default/shades.gif)
pete-stevers
post Sep 25 2008, 11:29 PM
saved from fire!
how bout carbs....
whatcha think andy?? (IMG:style_emoticons/default/poke.gif)
Eric_Shea
post Sep 26 2008, 12:14 AM
PMB Performance
Stop drooling Jeff... it's embarrasing, even from afar. (IMG:style_emoticons/default/lol3.gif)
sww914
post Sep 26 2008, 12:56 AM
I like the MFI part, you can do whatever you want when you have MFI as long as you get the space cam profiled to match your displacement, compression, and cams. Sure, it costs $1200.00 but MFI makes the most crisp, quick revving, sexy sounding engines. Super light flywheel, high compression and wild cams make for a fun ride to be sure. Dual plug it and you can get it to run well on pump gas at about 9.5:1 compression. The 6 bolt crank means that if you have an early 911 flywheel making the clutch work is a no brainer. Of course, if you build what I want, you'll loose some streetability for the sake of thrills. Really good thrills.
pete-stevers
post Sep 26 2008, 10:24 AM
saved from fire!
there is also an issue of being able to get the car through "air care" so dumping to much unburnt fuel out the pipes will be a consideration
sixnotfour
post Sep 26 2008, 11:24 AM
Haha you me both have that motor in pieces , we both should get off our ifs ands buts and get em done.
the motor your looking at already has this ? or its a concept ?
post Sep 26 2008, 11:33 AM
Resident German
QUOTE(pete-stevers @ Sep 25 2008, 09:29 PM) *
I think that a stock 3.6L with headers and modified chip will get you close to 300HP and will be magnitudes more reliable than anything you can build off your 3.0L core yourself ...
(IMG:style_emoticons/default/poke.gif) Andy
PS: Hey, you asked! (IMG:style_emoticons/default/biggrin.gif)
Root_Werks
post Sep 26 2008, 12:13 PM
Village Idiot
Steve's current 3.0 is a CIS motor and should get some decent mileage as is. I would agree with Andy, you'd wind up spending less money to get a stock 3.6 in your 914 or about the same with FI 300hp. Either way it's gonna be bucks.
pete-stevers
post Sep 26 2008, 02:56 PM
saved from fire!
three-six-schmee-six
i guesse i could throw it in the mix of possibilities....
but...
but i much prefer a vintage-ish motor /carbs or mfi
the big Q is to split with hard earned cash for early carerra with the possibility of a SS in the future
or...build out the 3.0sc
i drive the teener 5000kms a year max so milage is not a huge consideration,
thats what my wabbit is for (w a 1.6 engine) (IMG:style_emoticons/default/driving.gif)
Justinp71
post Sep 26 2008, 02:57 PM
He could easily add carbs and a cam and get the motor to come to life... Dougherty racing cams is the place to go.
If you get another motor there always is the risk that it may need some work, depends on what you get. Paul S. had to take his 3.6 apart a few times to get it from leaking, it might have had another problem to, not sure. And Andy had to put a new alternator in his...
Either way it will rock!
TravisNeff
post Sep 26 2008, 04:25 PM
With that early case you can do a short stroke 2.8, the best engine porsche never built. as quoted from Sportech.
http://forums.pelicanparts.com/showthread....e+porsche+built
- Lo-Fi Version Time is now: 27th September 2024 - 09:13 AM
