The exploding turn signal switch, Rebuild |
lmcchesney |
Feb 14 2004, 07:51 AM
Member Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None |
I recieved a replacement turn signal switch/ washer, wiper switch from Bob Bischoff, thanks again Bob, and installed the unit. Found my washer switch would not function and the high beam/low beam switch wasn't functioning also. Being a typical 914 owner, I did the usual. Yelp, took it apart. Got the washer to work(converted from pneumatic switch to electrical) but on working the turn signal switch, BOINGGGG! Pieces everywhere. Collected them up and using the restrunction techinque, "One of these things does not look like the other", got the switch back together, except for, that long metal flat rod that holds the, I believe to be, cancelation prong protruding into the center stering colum hole. WHERE DOES THIS THING GO?! How does the flat metal spring fit into the base and still allow insertion of the prong?
THanks, L. McChesney Attached image(s) |
SirAndy |
Feb 14 2004, 05:00 PM
Resident German Group: Admin Posts: 41,815 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(lmcchesney @ Feb 14 2004, 05:51 AM) WHERE DOES THIS THING GO?! what year and type is your car? this looks COMPLETELY different than my '73 assembly ... Andy |
lmcchesney |
Feb 14 2004, 05:15 PM
Body/chasis is 72, 1.7L.
Are you saying the switches from different years are different? My is as pictured. L. McChesney |
SirAndy |
Feb 14 2004, 05:23 PM
QUOTE(lmcchesney @ Feb 14 2004, 03:15 PM) Are you saying the switches from different years are different? very different! when i switched from my '70 harness to a '73 harness i could NOT reuse any of the steering column parts. i had to get a complete 73 assembly. and i know for sure that even in the later model years there were differences from year to year. do you have the windshield wiper switch at the column or at the dashboard? Andy |
TheCabinetmaker |
Feb 14 2004, 05:24 PM
I drive my car everyday Group: Members Posts: 8,309 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Yes, some years are different. Don't know about the 72, but a 73 will not interchange with a 75 or 76. The wiring connectors are different.
lmcchesney |
Feb 16 2004, 05:21 PM
Found the location for the flat spring. The unit is repaired.
Is there a location on our web site where I could submit a article of the repair with images. I have submitted the article to Wayne at PP but he hasn't published my other articles as yet. Thanks, L. McChesney |
lmcchesney |
Feb 17 2004, 04:15 PM
The TSS/WW unit is in and functions just right. Turn signals, hi/low beam, two speed wiper and washers. Success is nice. (IMG:style_emoticons/default/driving.gif)
L. McChesney |
fiid |
Feb 17 2004, 04:18 PM
Turbo Megasquirted Subaru Member Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
I'm pretty sur ethat you can get different year switches to work - I have a 924/944 washer switch in my car - I had to pull apart the connector and place all the wires in the original 914 one. It works nicely now though and I have an electric washer motor!
Lo-Fi Version | Time is now: 27th September 2024 - 10:10 AM |
