What does an engine weigh?, Type4 vs. V8 |
BravoHotel |
Feb 18 2004, 02:33 PM
Member Group: Members Posts: 153 Joined: 5-March 03 From: Columbus, MS Member No.: 399 |
What is the diff in weight between a type4 and V8? If the V8 has aluminum heads, what do you save...50lbs?
BH |
Jake Raby |
Feb 18 2004, 02:42 PM
Engine Surgeon Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
man, a V-8 is a heavy animal..... I have no idea. The block of a V8 alone weighs more than a TIV complete longblock for sure.
Mark Henry |
Feb 18 2004, 03:28 PM
V8 longblock (smallblock) 550lbs add rad, fan, hose, water, etc...
Plus the centre of gravity is higher. T4, what around 280lbs full dressed? |
JWest |
Feb 18 2004, 03:36 PM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
I agree with Mark Henry's weight estimates.
SBC heads: Early iron heads weigh the most - later (late '70s and newer) iron heads weigh less but can be prone to cracking. Chevy aluminum heads weigh a lot less that aftermarket (Edelbrock, Trick Flow, etc.) because the aftermarket are much thicker. So going from early iron to Corvette aluminum saves a lot (maybe as much as 40lbs?), but late iron to aftermarket aluminum gives very little savings (<20lbs I would guess). |
MattR |
Feb 18 2004, 03:45 PM
Advanced Member Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California |
My brother laughed when he heard a T4 short block can be picked up and moved. His ford 289 was a big motha'.
fiid |
Feb 18 2004, 04:13 PM
Turbo Megasquirted Subaru Member Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
QUOTE(Mark Henry @ Feb 18 2004, 01:28 PM) V8 longblock (smallblock) 550lbs add rad, fan, hose, water, etc... Plus the centre of gravity is higher. T4, what around 280lbs full dressed? Yeah. I think the sixes weigh in at around 400, right? The subaru motor is slightly heavier than a TIV, and puts out 280horse & 280ft/lbs or so. All the weight is on the bearing line. Scorchio. I have a spare 1.8 subaru single turbo engine that needs a rebuild if anyone is interested in doing a project. I have an early style (tailshift) motor mount bar for it. I will even help with the project. It has a distributor, so you don't have to do electronic ignition, unless you want. It puts out 150 horse in stock trim with low-ish boost and no intercooler. That can be improved with better boost control. |
BIGKAT_83 |
Feb 18 2004, 05:21 PM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
Here is a copy of a thread from the Pors-chev group about engine weight. I know this is a all aluminum LS1 vs a 3.0 six.
I have seen this issue pop up on this forum from time to time well, I finally got an answer to this myth. I took the time today to take my 1980 911 3.0 SC engine and 2000 GM LS1 Corvette engine to the scales to weigh them and this is what I found out: My fully dressed 1980 3.0 Porsche engine ready to install weighed 472 lbs. Factor in the weight of the oil in the 10 quart oil tank needed to support the 3.0 engine, then your engine plus oil tank weight jumps up to 490. 5 lbs. at the rear of thevehicle. (One gallon of oil is 7.4 lbs. Ten quarts is 2.5 gallons, 2.5 x 7.4 = 18.5lbs.) My fully dressed 2000 LS1 Corvette engine ready to install with the engine computer and wire harness, complete exhaust system, engine mounting brackets, AC compressor, alternator, custom water pump adapter, transmission adapter plate and flywheel weighed 434 lbs. This is a rear vehicle weight savings of 56 lbs. over the Porsche 3.0 engine. I did not weigh the above engines with the transaxle or clutch assembly bolted to either engine. These parts would be used for both installations and their weights would obviously cancel. Just wanted to share this information with you guys. ToyJet. |
fiid |
Feb 18 2004, 05:25 PM
Yeah - I heard the all-ali V8s actually improve the handling of Triumph Spitfires (not hard) because they weigh less than the CAST IRON 1.3 LITRE four banger that comes stock.
I am super suprised by it being lighter than a 6 though. I guess this is why the v8 people aren't all whining about the handling changes..... even if they are running iron engines, the 6 is pretty heavy. |
Mark Henry |
Feb 18 2004, 06:13 PM
QUOTE(BIGKAT_83 @ Feb 18 2004, 03:21 PM) vehicle weight savings of 56 lbs. over the Porsche 3.0 engine. Did you add the rad, hoses and water? If not it might be break even. |
East coaster |
Feb 18 2004, 08:08 PM
Senior Member Group: Members Posts: 1,752 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None |
I was surprised to find out that the 964 shop manual listed my 3.6 engine at a whopping 540lbs!!! I have to believe that's on the high side, but that's right from the Porsche factory service manual? Now I guess if I take that weight and subtract the A/C compressor/bracketry, power steering pump/bracketry, extra pulleys, air box, hulkamania exhaust system, dual mass(keyword) flywheel, it should bring it down a few lbs! But damn, it's still nearly twice the weight of the 4!!
Gint |
Feb 18 2004, 10:13 PM
Mike Ginter Group: Admin Posts: 16,093 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I tell ya, when we pulled the motor out of my 914/6, I was a bit surprised how much heavier it was than a 4. It felt like twice as much.
JWest |
Feb 18 2004, 10:31 PM
An LS1 is not the same as a classic small block, and if I'm not mistaken the Vette LS1 has an aluminum block.
I have heard 550 lbs for the SBC for a long time from many sources. |
Andyrew |
Feb 18 2004, 10:59 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Fiid, you've got me thinkin.. Is it the same mount as the engine your installing right now? For like say the person wanted to upgrade to that motor later on in life when daddy says that Im alowed to drive a street legal monster??
PM me some details.. Im just bench racing right now.. Andrew |
fiid |
Feb 19 2004, 03:11 AM
It's a different, older engine. It ought to put out about 180 - 200 horse with a proper rebuild and tuning.
WHats up with that 911 motor you have in the classifieds? Fiid. |
Sammy |
Feb 19 2004, 04:05 AM
. Group: Members Posts: 1,190 Joined: 21-January 03 From: Orange, Ca Member No.: 178 |
Standard chebby small block with iron heads and light weight headers is about 525 lbs.
Aluminum intake manifold saves 25 lbs. Aluminum heads save 50 lbs. to get it down to 450 lbs. 3 liter six is 419 lbs according to the factory manual but I don't think that counts the muffler and I know it doesn't count the oil tank and associated hardware. I am surprised by the posts that say a type 4 is under 300 lbs. My estimate was 325 lbs. fully dressed with HEs and stock fuel injection. Anyone actually put one on a scale to see? |
cha914 |
Feb 19 2004, 09:30 AM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
My T4 with heads/clutch/flywheel(lightened) and carbs weighed ~400lbs when it was shipped...but that included the wooden box it was in...so I guess it was ~300lbs before the box.
I know that didn't help much ...but its all I got. Tony |
Andyrew |
Feb 19 2004, 09:37 AM
The 911 motor I parted. Got some good cash, but that went elsewhere.
I still have lots of parts from it, and most likely will go to ebay. Like Oil cooler.. im watching one on ebay right now.. PM me with the details.. Or email it to me.. Andrew adalen@pacbell.net |
J P Stein |
Feb 19 2004, 01:37 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Here, write this down:
kg lbs-- models-- Source 182 400 2.4L E, S, RS 1972-73 Tech. Spec. book 183 403 2.4L T 1972-73 Tech. Spec. book 200 440 2.7L 1975-1977 Aichle - 911 Engines 190 419 78-83 930/09,19,10 78-81 78-81 & 82-83 Tech Spec. book 200 441 78-83 930/03-08,13-17 78-81 & 82-83 Tech Spec. book 190 462 3.0L 1980-82 Aichle - 911 Engines 219 483 84-87 930/20,26 84-87 Tech Spec. book 220 485 84-87 930/21,25 84-87 Tech Spec. book 219 482 3.2L 1987 - 1988 Aichle - 911 Engines 238 524 964 89-94 M64/01,02 ROW &US 964 Tech Spec. book 226 497 M64/03 RS 964 Tech Spec. book 275 605 M30/69 3.3L 964 Tech Spec. book 276 608 M64/50 3.6L 964 Tech Spec. book 232 510 M64/05-08 993 Tech Spec. book 221 487 M64/20 993RS v-ram w/o ZMS 993 Tech Spec. book 230 507 M64/20 993RS v-ram w/ ZMS 993 Tech Spec. book __________________ Some variation between sources, it seems. |
brant |
Feb 19 2004, 03:28 PM
914 Wizard Group: Members Posts: 11,739 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Awesome JP....
anybody have the same tech info for the early aluminum block 1965-1967? b |
J P Stein |
Feb 19 2004, 04:17 PM
Hay, I stolt it off the bird list.....they worn't miss it.
I assume those weights are fully dressed. My son and I picked up the 2.7 long block (to put it on the stand) quite easily......he's strong, but he only had half the weight. I am somewhat less strong (IMG:style_emoticons/default/rolleyes.gif) Me and 3 other guys picked up a sb Chebbie long block.....that was tougher & I was young. I understand the early aluminum case is a fair amount heavier than the mag case...20-30 lbs....but don't quote me (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 11:02 AM |
