Squeaking noise, Please help me track it down! |
zonedoubt |
Sep 17 2009, 02:53 PM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
I em experiencing a squeaking sound when the car is moving. It's a squeak when going slow (acceleration or deceleration) and turns into more of a "rubbing" sound when speed is higher. The sound is the same with brakes applied or with the clutch out. No noise when the car is not moving.
I can't 100% tell if it's coming from the front or back because of ambient engine and road noise, but am leaning more towards the rear. Where should I start to look? Wheel bearings? |
underthetire |
Sep 17 2009, 02:57 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
I em experiencing a squeaking sound when the car is moving. It's a squeak when going slow (acceleration or deceleration) and turns into more of a "rubbing" sound when speed is higher. The sound is the same with brakes applied or with the clutch out. No noise when the car is not moving. I can't 100% tell if it's coming from the front or back because of ambient engine and road noise, but am leaning more towards the rear. Where should I start to look? Wheel bearings? Could be rear bearings. Mine made more of a groan. CV joints ? |
McMark |
Sep 17 2009, 04:51 PM
Roof?
jt914-6 |
Sep 17 2009, 05:09 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
Roll bar/suspension bushings????
914_teener |
Sep 17 2009, 05:13 PM
914 Guru Group: Members Posts: 5,245 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
benalishhero |
Sep 17 2009, 05:18 PM
Member Group: Members Posts: 313 Joined: 28-November 07 From: Portland, Maine Member No.: 8,384 Region Association: North East States |
Good to know I'm not the only one with a sqeaky roof! Maybe a brake backing plate? |
zonedoubt |
Sep 17 2009, 07:37 PM
Thanks for the ideas. I'll check on those tonight.
I was thinking speedo cable as a possibility. |
Elliot Cannon |
Sep 17 2009, 07:44 PM
Good to know I'm not the only one with a sqeaky roof! Maybe a brake backing plate? (IMG:style_emoticons/default/agree.gif) I had a weird squeek as well. As I was driving, I pushed up on the back edge of the roof and the squeek went away. |
championgt1 |
Sep 17 2009, 08:05 PM
Don't embarrass me Filmore! Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/agree.gif) Same thing happened to me.
zonedoubt |
Sep 18 2009, 07:25 PM
I thought I'd start with the easy checks first. Unhooked the speedo cable at the speedo drive and at the speedometer. Sprayed some lube in the cable ends. Reattached, test drive, no more squeaks!
Elliot Cannon |
Sep 18 2009, 08:30 PM
I thought I'd start with the easy checks first. Unhooked the speedo cable at the speedo drive and at the speedometer. Sprayed some lube in the cable ends. Reattached, test drive, no more squeaks! Oh Yeah? Well I STILL think it's the roof. (IMG:style_emoticons/default/lol-2.gif) |
zonedoubt |
Sep 19 2009, 09:50 AM
WIth so many "check the roof" replies, I don't think I described my squeak properly. (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 27th September 2024 - 08:10 AM |
