How big of a V8 will fit?, search won't return anything for me... Grr! |
HeloMech |
Sep 18 2009, 09:31 AM
Go Ahead, Get Pistoph! Group: Members Posts: 691 Joined: 31-August 05 From: Roy, WA Member No.: 4,718 Region Association: Southern California |
ok, so now I've got this bright idea...
police interceptor... nobody seems to want it... however, it has LT1 5.7L in it. It's rated just under 300hp as I recall. So... uh.... will it fit? (IMG:style_emoticons/default/smash.gif) |
zymurgist |
Sep 18 2009, 09:44 AM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
It's a small block Chevy, so probably. I do remember hearing a conversation at the ECC about LT1's with their reverse flow cooling etc. so I'm not 100 percent sure.
Bruce Hinds |
Sep 18 2009, 10:00 AM
V-8 madness Group: Members Posts: 734 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
The reverse flow cooling would actually be an advantage! It will surely fit! Actually most anything will fit. There is a guy in Colorado that has a 455 olds or buick in his.
B |
SLITS |
Sep 18 2009, 10:35 AM
LT1 = cast iron block, aluminum heads of early style ports ... no gain except for the loss of 25 - 50 lbs of weight.
'94-'96 is the pin drive, reverse flow water pump .. big ass dude. |
zymurgist |
Sep 19 2009, 07:47 AM
You want the Corvette or Camaro LT1 to get the aluminum heads. The Impala / Buick Roadmaster / Cadillac Fleetwood LT1's came with iron heads.
BarberDave |
Sep 19 2009, 03:36 PM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
Thats like asking " How far is up" Hell as big as you can do, ever seen Rick's " Alein " . Small block or big block or sick block , If you can engineer it safely it can be done. Go to it and supprise us!!!! Dave (IMG:style_emoticons/default/slap.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 09:49 AM |
