Crankcase breather with carbs., How do you attach a hose to the filters? |
Thack |
Nov 11 2007, 11:32 PM
Member Group: Members Posts: 283 Joined: 1-June 05 From: Houston, Tx Member No.: 4,182 |
For those running dual carbs, how do you attach a crankcase breather hose to the filters? Especially if you have K&Ns, which I plan to replace. Do you run two hoses? Got pics? (IMG:style_emoticons/default/sawzall-smiley.gif)
rhodyguy |
Mar 4 2008, 09:20 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
or...with 2.0 heads with the drain/vapor return tubes, you run a single vent line from the oil fill tower to the cb style foam filled box and lines from the outlets on the box to the heads. you need to ensure the bb is mounted high enough for the oil to flow to the heads and not puddle in the lines. with the cb bb, squeezing the dirty oil out of the foam filter and soaking up the small ammount in the bottom should be considered part of routine maintenance.
k |
Lo-Fi Version | Time is now: 27th September 2024 - 09:54 AM |
