Crankcase breather with carbs., How do you attach a hose to the filters? |
Thack |
Nov 11 2007, 11:32 PM
Member Group: Members Posts: 283 Joined: 1-June 05 From: Houston, Tx Member No.: 4,182 |
For those running dual carbs, how do you attach a crankcase breather hose to the filters? Especially if you have K&Ns, which I plan to replace. Do you run two hoses? Got pics? (IMG:style_emoticons/default/sawzall-smiley.gif)
rhodyguy |
Mar 6 2008, 08:29 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
i imagine those ebay vent items will do the job. to drill and tap the heads you'ld have to pull them which just opens a big can of worms. the "while you're in there" scene. if you do the valve covers, bear in mind the correct orientation of the covers when in place and putting the tubes in so they don't interfear with the bales.
the cb bb is not a sealed unit but the foam element does a good job of keeping the vapor mess to a minimum. k |
Lo-Fi Version | Time is now: 27th September 2024 - 09:00 AM |
