1.8 not running right, need help., after Petronix install, uninstall. Update - running! |
Cevan |
Mar 26 2008, 08:14 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
I had gotten a Petronix electronic ignition module (1847V). Prior to installing it, the car had been running great with the points (I know, should have left well enough alone). I installed it per the instructions and cranked the motor over but nothing. I checked all my connections and cranked it over again and nothing. So I removed it and put the points back on.
When I go to start it, it seems that only 2 of the cylinders are firing. It was definitely idling low. My CHT gauge never really moved (it's on #3) so I suspect that 3 and possibly 4 are not firing. I drove it about 1/4 mile and no power. Could I have flooded 3 and 4 when I had the Petronix unit on? I'm going to let the car sit overnight and try it again in the morning. Could I have damaged something with the Petronix unit? |
Thack |
Mar 28 2008, 12:53 PM
Member Group: Members Posts: 283 Joined: 1-June 05 From: Houston, Tx Member No.: 4,182 |
I forgot how the trigger points are wired to the distributor. Maybe someone will chime in. I know that they will provide the pulse for triggering the injectors in pairs. I don't think it's 3 and 4 together. More like 1 and 3 then 2 and 4. I thought maybe you knocked the connection loose by accident.
Now I think you may just have bad plugs. Maybe something was loose or faulty with the Pertronix and it didn't create spark, thusly it fouled your plugs. |
Lo-Fi Version | Time is now: 27th September 2024 - 07:45 AM |
