longer Intake manifold studs, can't find them at Raby's or PP |
VaccaRabite |
Apr 5 2008, 10:31 PM
En Garde! Group: Admin Posts: 13,553 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I am looking for longer intake manifold studs.
If I use one of the thick intake gaskets, my current studs are not quite long enough to bolt on my carbs. Where can I find longer ones? I did not see them at Raby's or PP, and trying to search at AA right now is neigh impossible. My search is hampered as I don't actually know the dimensions of the stock studs. I guess the simpler solution would be to buy another set of thin intake gaskets. But I have a new set of the thick ones, and I understand that they are better to use. And, yes, I am aware that I am asking noob-tastic questions this evening. Zach |
rhodyguy |
Apr 6 2008, 09:19 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
i'm confused. with phenolic gaskets and cb tall manifolds, the stock intake studs work just fine for me. are you guys trying to use cut washers under the nuts?
k |
VaccaRabite |
Apr 6 2008, 09:52 AM
i'm confused. with phenolic gaskets and cb tall manifolds, the stock intake studs work just fine for me. are you guys trying to use cut washers under the nuts? k Yes. But even if I was not trying to use a washer, there is not quite enough stud there to put a nut on and expect it to stay. Zach |
Lo-Fi Version | Time is now: 27th September 2024 - 05:40 AM |
