longer Intake manifold studs, can't find them at Raby's or PP |
VaccaRabite |
Apr 5 2008, 10:31 PM
En Garde! Group: Admin Posts: 13,553 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I am looking for longer intake manifold studs.
If I use one of the thick intake gaskets, my current studs are not quite long enough to bolt on my carbs. Where can I find longer ones? I did not see them at Raby's or PP, and trying to search at AA right now is neigh impossible. My search is hampered as I don't actually know the dimensions of the stock studs. I guess the simpler solution would be to buy another set of thin intake gaskets. But I have a new set of the thick ones, and I understand that they are better to use. And, yes, I am aware that I am asking noob-tastic questions this evening. Zach |
Dave_Darling |
Apr 6 2008, 12:35 AM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Won't plain M6x1.0 (thread) in an appropriate length work fine? You should be able to get that from a good large hardware store, or at least a big auto parts place. Failing that, Caterpillar Tractor carries lots of metric stuff...
No, I don't know what the appropriate length is; if you have stock studs measure them and add however much more length you think you need. --DD |
Gint |
Apr 6 2008, 12:39 AM
Mike Ginter Group: Admin Posts: 16,093 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Won't plain M6x1.0 (thread) in an appropriate length work fine? Is that a question also or a statement? I don't know either. I can assume it would be fine, but then I have one already that won't come out, so I don't want to just stick any old piece of hardware in my head. Measuring is no sweat. I'm pretty sure they're 30mm. Edit: They are 40mm as I indicated in my next post. And they're 8x1.25 not 6x1.00. This post has been edited by Gint: Apr 6 2008, 12:49 AM |
Dave_Darling |
Apr 6 2008, 01:03 PM
Lo-Fi Version | Time is now: 27th September 2024 - 05:38 AM |
