anyone know weber 34 ICT carbs? |
the4ork |
Apr 10 2008, 09:34 PM
Newbie Group: Members Posts: 22 Joined: 9-April 08 From: Lemoore,CA Member No.: 8,900 Region Association: None |
the car runs great!!! when you got your foot in it...
but im having a hell of a time getting it to idle smoothe... if your familiar with them please help me out... i have to have the idle mixture all the way out almost, and the speed screw cranked in pretty good to get an idle... but this keeps it about 2k rpm, this is the only way to get a reliable idle... to get it down to about 900 i have to back out the idle jets from the carb, the big brass ones on the top side of the carb, with the o-ring... but if you back them out they move around while your driving and then the idles all screwed up again... im thinking my idle jets are too small, which is why backing them out helps... i think they are .52? jets i'll have to double check... but does it sound like im on the right track? and where the heck would i get jets for those things? also i pulled the plugs out and they are a little white, maybe i should get bigger idle and main jets? |
Elliot Cannon |
Apr 10 2008, 11:30 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
Pull the idle jets out and see if they are clogged with something. You might need a magnifying lens. I'm having the same symptoms with my 44idf. One of the idle jets on one of the carbs keeps clogging and I can't figure out why. New tank, lines and filters.
Elliot |
Lo-Fi Version | Time is now: 27th September 2024 - 09:52 AM |
