3000 rpm idle, Car arrived. Sitting at Mall now |
eldiosyeldiablo |
Jan 3 2004, 05:28 PM
Member Group: Members Posts: 129 Joined: 19-August 03 From: Roswell, GA Member No.: 1,047 |
Hey everyone. The yellow '74 914 arrived on the truck today. I met the guy at the mall. I'll post another posting about the fiasco of getting the car off the truck.
Problem: Start the car and it idles at or above 3000 rpm. There was one or two hoses that looked to go into the air box that were not connected them. I reconnected them but that did not help. There is a hole on the drivers side on the engine block that does not have any hoses connected. The air box to throttle body does not seat all the way down. I tried to press it down but it would not stay. I left the car at the mall as I am afraid to drive the car around with it idling so high. I did a couple circles in first and second gear. Please help!! I do not have a haynes manual yet as I did not expect to have any problems the very first day that it arrived. Argh!!! The wiring is definately a hack job. I'll post pictures later with circles around the various parts. I just got home and I am trying to relax. Very bad day. (IMG:style_emoticons/default/sad.gif) We my very first 914 and the first immediate problem. -David |
JeffBowlsby |
Jan 4 2004, 03:27 PM
914 Wiring Harnesses Group: Members Posts: 8,663 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
There is a 'long-blade' male wire terminal on the harness and a standard 25mm female on the CHT. Just pull the two wire apart and replace the wire terminals if needed. GOod electrical contact is important here.
I have a stash of the brown housings, but typcially repalce them with a new OEM housing becasue I can get those new. That area of the engine bay shouldnt really get that hot unless its touching the engine case. |
Lo-Fi Version | Time is now: 27th September 2024 - 01:32 PM |
