Can't get rear heater fan to come on, Even in AZ we need heat sometimes. |
3d914 |
Jan 2 2004, 02:15 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
I've been assembling all the parts to re-install heat in my teener, and now I'm down to checking out all the wiring. But I'm not getting any power to the rear heater fan (in engine bay).
I've cleaned up the connectors and wiring from the heater switch behind the shifter (ground side of the circuit). It comes out at pin #9 on the forward 14-pin connector on the relay board. Power should be going to pin #11 of the same connector, but Im gettin zip. This #11 connects to pin #10 of the lower-right 12-pin connector on the relay board - which bridges to pin #11 - then over to #87 of the relay. I'm getting power at #30 on the relay - but don't have a way to check where its going from there. The relay is new, and I've swapped with others - but keep ending up with no power. Any ideas - what I might be missing? TIA, |
banderson |
Jan 6 2004, 02:30 PM
Member Group: Members Posts: 88 Joined: 22-August 03 From: Massachusetts Member No.: 1,064 |
Gerard, You are quite mistaken. Last monday, and again Wednesday, were nice. It had rained over the weekend and the salt had washed away. THe temperature was in the 30s and the top was off. I have a 30 mile commute each way. I wore an extra layer and a hat but there was no traffic due to the vacation week and I was moving right along (IMG:style_emoticons/default/mueba.gif)
I find that with the top off, warm air gets sucked right through and I am sitting is a pocket of warm air with a cool breeze circulating around my head. Totally comfortable, Totally awesome. As for your blower motor, keep it, and use it if you like. |
Lo-Fi Version | Time is now: 27th September 2024 - 11:04 AM |
