FS:914/6 Race Car, Race Ready, SOLD!, Found a good home! |
danmuldowney@comcast.net |
Aug 5 2008, 03:39 PM
Newbie Group: Members Posts: 9 Joined: 7-October 07 From: minnesota Member No.: 8,193 |
1974 Porsche 914-6 2.2 liter Race Car: Very fast. Very light. Drives, handles and shifts like a shifter cart, only bigger! Everything that can be done to the car, and still be safe, has been done! Current PCA and Vintage / VSCR log books. Professionally built and maintained by Bob Viau and his team at Auto Edge for the last 10 years. PCA GT5R or S class. PCA, NASA, SCCA, POC and Vintage legal. Current PCA inspection, (4/20/07).
Very reliable. Recent rebuild on engine and transmission with test hours only. New suspension. 15 podium finishes in last 20 starts. Engine: (Andail / Porsche Motorsports Specs. Recent rebuild with test hours only) • 2.2 liter twin plug six cylinder • Webber 40 carburetors • Induction Research flowed 2.4 liter Porsche twin plug heads • Extensive machining to case and crank • Pauter Rods, 70 mm stroke • J&E Pistons custom coated 81mm. 9.8/1 compression • Custom Web Cams, 104/102 grind • Titanium retainers with Jerry Woods high tension valve springs • Tuned length headers with EGT probes, Jet Hot ceramic coated • Sport tuned stainless steel muffler • Peterson 16qt front mount oil tank with heater, front cooler and Accusump pre-lube • All Aeroquip hoses with Earls fittings • Electromotive crank fire – waste spark ignition • Turbo valve covers • New wiring with blade style fuses, all labeled • Front mounted case breather system with catch can • Facet electronic fuel pump with micron filters • 17 gallon fuel cell Suspension: (New suspension with test hours only) • Front: Bilstein RSR 220/100 valveing Mono ball mounting • Koni double adjustable rear. • Hypercoil springs • SMR Bump steer kit • Adjustable front sway bar with mono ball links • All mono ball or Delrin bushings Brakes: (This car has way more brakes than it needs!) • 1986 930 front calipers and rotors on the front and rear, • Cross drilled rotors • Stainless steel lines • Adjustable proportioning valve Sequential Transmission: • Porsche case / bell housing containing a Hewland Webster Mark 9 with Mark 5 gears • PBS sequential shift linkage • New dog rings • Ratios: Ring and Pinion: 8/31 1st 12/31 2nd 17/29 3rd 16/23 4th 19/24 5th 24/27 • Quafe limited slip differential Tub / Chassis: (Very stiff chassis! Absolutely no rust!) • Porsche tub with 914 GT fiberglass body panels from GT Racing • All fiberglass body except door skins • Full custom roll cage welded to the chassis with all suspension points tied in • NASCAR style intrusion bars on the driver side. • Factory rear suspension reinforcement plates welded in with additional custom reinforcement • Reinforced rockers • Floor pans and rockers replaced last year with NOS parts. • Paint is a 7 ½ out of 10, Rino-tape on the front end. Some race rash on Rino-Tape in the front. Small dent on the top of the windshield hoop otherwise in great shape! • Custom gages. Tachometer, Oil Pressure, Oil Temp, EGT gages for each cylinder • AIM Data Acquisition System • Custom center panel with EGT switches, Ignition, Accusump activator, Cool Suit air and water regulators, Radio push to talk. • Rebuilt pedal cluster with bronze bushings, (stock was prone to fail) • 914 GT Engine cover, (for better cooling) • Removable GT Racing down force wing, (additional lip spoiler included) Safety: • Autoshield aluminum seat bolted to the floor and the roll cage • Lexan windshield with anti scratch coating. • Large convex rear view mirror • Areo convex side mirrors • SPA fire system with jets on the fuel cell, engine and driver. Activation switches on the outside and inside of the car • Battery cut off switch • New Simpson 6 point harnesses • Cool Suit air and water system, (Cool Shirts not included) • Wired for radios, (radios not included) • Removable Sparco steering wheel with quick release Spares included: • 3 Front air dams • 2 Sets of 8 x 15 Fuch wheels • 8 New Hoosier racing slicks • 6 Fuel cans • Custom fuel funnel • Set of new brake pads • Several fuel and oil filters • Some other little parts, (shift cable, clutch cable, bumper, engine cover, engine shroud) I would like to get $25,000 or trade for 993, 996, 964, or 308. [/b] Contact danmuldowney@comcast.net or (952) 941-2039 |
Aug 20 2008, 01:37 PM
The car weighs 2000 lbs. The horsepower is just shy of 250. As for the muffler it is a Dansk twin outlet stainless steel "performer" muffler. Most tracks have a sound check and this muffler always passes. I dont know the decibles however.
Yes the car has a clear title. Since the car is no where near "street legal" the title is sort of un needed. |
Lo-Fi Version | Time is now: 27th September 2024 - 04:53 AM |
