Outer CV Joint Reassembly - HELP |
vesnyder |
Sep 1 2008, 04:58 PM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
I had to remove the rear drivers side trailing arm and thought "while I was in there" I would repack the outer CV Joint. Took it completely apart and cleaned the balls and cage and removed most of the old grease and now I cannot get it back together? What is the trick? Of course I did not mark it to ensure it is assembled the same as it was before - am I screwed? I seem to get it on cock eyed before it goes no farther, then one or more of the ball bearings fall out - help!
This is one dirty job!! |
vesnyder |
Sep 2 2008, 10:21 AM
Ben - Thanks. Looks like may have been assembled before greasing, which means I will have to remove the splined end to enable the greasing. I will also remove completely from tha car to work with it on the bench!
Lo-Fi Version | Time is now: 27th September 2024 - 01:15 AM |
