Oh no! Foam is everywhere!, Been browsing Bowlsby's site... |
bondo |
Jul 27 2005, 07:49 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
We all know and love that foam the factory stuck in hidden places that traps water and causes rust... I knew about the front and rear of the inner rear fenders, and the ends of both trunk lids... Brace yourself, then check out the pic below! I was hoping to eliminate the foam during my restoration, but now it seems hopeless.
(IMG:http://members.rennlist.com/914_collectibles/zRareDoc08.jpg) |
charliew |
Sep 4 2008, 11:00 AM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
I know this is an old thread, I came here from a newer one but I am wondering if the wax has been put in the cavities and you weld or cut on these cavities will they catch on fire?
sww914 |
Sep 4 2008, 11:15 AM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
I know this is an old thread, I came here from a newer one but I am wondering if the wax has been put in the cavities and you weld or cut on these cavities will they catch on fire? Yes. I've done it. As I mentioned in another thread, VW uses a lot of cavity wax. I've set a couple of VW's on fire with a plasma cutter cutting out frame rails that needed to be replaced. When you're cutting and welding you always need to keep an eye and your nose open for fires. I knew it might happen so I had a water hose and an air hose next to me to take care of it as well as a fire extinguisher nearby. I was able to use air on one and water on the other without any damage, no big deal. |
Lo-Fi Version | Time is now: 27th September 2024 - 12:33 PM |
