Trans ratio, 914/4 versus 6 |
retrotech |
Jan 9 2004, 11:13 PM
retrotech Group: Members Posts: 470 Joined: 2-November 03 From: Mosier, Oregon Member No.: 1,302 |
Can some one tell me the difference between 4 cyl. ratios & 6 cyl. Basically are the gears raios closer on which one? Which has the lower ratio, ie lower max speed per gear.
Thanks |
redshift |
Jan 9 2004, 11:58 PM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
Hey, found what I was looking for, and my memory works!
http://members.rennlist.com/chuxter/901&915ratios.htm Changing either car, to the other's transaxle (stock) would not be a huge change. If you have MS Excel, you can d/l the ratios.xls, and play with speeds_in_gears. I deleted all the rpm cols. except for 3500-4500 and redline. M |
Lo-Fi Version | Time is now: 27th September 2024 - 08:39 AM |
