Please School me on Engines |
mambodave |
Sep 17 2008, 08:24 PM
Newbie Group: Members Posts: 20 Joined: 16-September 08 From: Charlotte NC Member No.: 9,557 Region Association: None |
1973 1.7.
I think I want to keep a 4.. because of weight, etc, and honestly everyone is doing sixes, so thinking about building or buying a bad ass 4.... Whos running high HP 2.0 to 2.2? What carb and or exhaust set up are you running. What are the potential differences in a 2.0 and 2.2 (baring size) What am I going to run into droping in a "new" 4, (what else will I need to change?) Any threads on upgrading a 4? I see tons on upgrading to a 6. And who's crating and selling them? (if anyone) Any help is greatly appreciated. Dave |
Todd Enlund |
Sep 17 2008, 11:07 PM
Resident Photoshop Guru Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
1973 1.7. I think I want to keep a 4.. because of weight, etc, and honestly everyone is doing sixes, so thinking about building or buying a bad ass 4.... Whos running high HP 2.0 to 2.2? What carb and or exhaust set up are you running. What are the potential differences in a 2.0 and 2.2 (baring size) What am I going to run into droping in a "new" 4, (what else will I need to change?) Any threads on upgrading a 4? I see tons on upgrading to a 6. And who's crating and selling them? (if anyone) Any help is greatly appreciated. Dave What's your budget? Stage I - dump the progressive Weber and get either D-Jet or a pair of 40 IDFs. Stage II - build your 1.7 into a 1911 with a set of 96mm pistons/cylinders. Stage III - Find a 2.0 and refresh it, or build it into a 2056 Stage IV - Build a 2270 with aftermarket FI or a pair of 44 IDFs. Stage V - Trade $$ for HP direct from Jake. I'm on the slow train direct to Stage IV... building a 2058 as I can acquire parts. Mine will be a 2058 because the crank that I got is a 78mm rather than the more common 78.4 mm stroker. |
helios |
Sep 18 2008, 06:50 PM
Member Group: Members Posts: 234 Joined: 15-May 08 From: Bellingham Wa Member No.: 9,055 Region Association: Pacific Northwest |
Stage II - build your 1.7 into a 1911 with a set of 96mm pistons/cylinders. 96mm pistons/cylinders - 1.8L P/Cs? (IMG:style_emoticons/default/confused24.gif) The reason I ask, is I had someone mention they thought the 1.8 P/Cs on a 1.7 block took the motor out to a 1911. I had assumed I only had a 1.8. |
Lo-Fi Version | Time is now: 27th September 2024 - 12:28 PM |
