Understanding and Improving the heater... |
Rod |
Oct 11 2008, 02:37 PM
Senior Member Group: Members Posts: 617 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England |
I have just replaced the heater blower and control panel on my 914 and the front trunk blower now works for the first time The previous owner to me covered over the dash vents with vinyl, so I have uncovered and trimmed around these too.
I have totally stripped out the interior, sorted any rust (er... none ) dynamatted the whole interior, put in extra soundproofing, fibreglassed over and repaired the back pad where the board/wood had perished and fitted a new grey loop carpet set from Appearance and Performance, phew. Looks fabulous and returning to perfect condition Now as I understand it, the dashboard levers work like this... 1. Top lever FRESH air vent and fan control 2. Middle Lever Controls direction of FRESH air delivered by above lever (left footwell, right dashboard.) 3. Bottom Lever Controls direction of HEAT from 4 below. (Again far left footwell, Right Dash vents) 4. Lever between seats Controls rear fan and therefore HEAT into cabin. So the front fan plays no part in heating the car whatsoever, just FRESH air. HEAT is controlled directly by the lever between the seats (the direction of which is controlled by the 3rd land lowest lever on the control panel) So, if I am correct with the above can you tell me why hot air only comes from the drivers side? It is really hot air on this side and blown with quite a force, yet the passenger side is cool.. I know there are differences between 73 and 74 cars in that the earlier cars (like mine) have a rear fan that only blows down the drivers side and later cars had a T piece which splits the air from the blower and connects to the passenger side, but is this why it is cold on the ps?? Surely it wasn't that bad from the factory in '73?? Long post sorry, but hopefully concise regarding my problem.. My wife is an Aussie and is complaining that she gets cold, so I'm determined to get more heat on her side if possible. Cheers (IMG:style_emoticons/default/beerchug.gif) |
Rod |
Oct 11 2008, 03:29 PM
Awesome a very constructive answer thanks (IMG:style_emoticons/default/smile.gif)
There is air being blown through the under dash vent so that makes me think that the pipework is intact. But surely ALL of the air coming from the back through the sills should be warm as it goes through the heat exchangers first? Therefore if there is a flow of air at dash end this means that all is working? or can cold air be forced down the sill pipes if the flapper valves have malfunctioned? |
Lo-Fi Version | Time is now: 26th September 2024 - 11:13 PM |
