throttle body sticking, on return |
jimkelly |
Oct 18 2008, 07:05 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
i was driving around yesterday - when all of a sudden my engine reved up extreme - i shut down and pulled to the side of the road - i figured my throttle cable snapped or my return spring popped off.
so i looked under the hood and all looked ok and then i pulled up the carpet to see what was going on near my gas peddle but all looked ok. drove home about 5 miles after gettting a push to get started - different problem - al the way in 3rd gear, shutting engine down when i hit 60mph, made it thru several tricky intersections - finnaly stalled out two houses from mine because my neighbors where chatting in the street blocking my path home. two problems - the lever on my TB - several times - returned from full open to about 1/4 open - got stuck there? kink in throttle cable somewhere it think? cable are not twisted in center console. and it seems no matter what spring in put on my throttle body - it does not seem to pull it closed fully. can it be just gummed up? Attached image(s) |
r_towle |
Oct 18 2008, 08:40 AM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
You have been warned.
Its winter season now....stop driving your car and start working on the list of things todo on your car. Get out the jack stands and assume the position Rich |
Lo-Fi Version | Time is now: 27th September 2024 - 11:51 AM |
