Fuel Pump, Webers |
Fuel Pump, Webers |
Todd Enlund |
Oct 24 2008, 01:07 PM
Resident Photoshop Guru Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
I'm going to need a fuel pump for carbs. Any suggestions? I've heard mixed opinions on the Facet pumps. I'm looking at Holley pumps on eBay... are they robust enough that I can think about buying a used one? And then there's the question... mount it by the gas tank, or in the engine bay?
Elliot Cannon |
Oct 24 2008, 01:54 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
You can't PULL a liquid!
Todd Enlund |
Oct 24 2008, 01:59 PM
You can't PULL a liquid! Yeah, but if the pump is lower than the tank, it could still be located in the engine bay... fuel would run to the engine bay even without a pump (IMG:style_emoticons/default/biggrin.gif) I was leaning towards front mount anyhow, if for no other reason than the pump would be better protected. |
Elliot Cannon |
Oct 24 2008, 04:46 PM
[quote name='Todd Enlund' date='Oct 24 2008, 12:59 PM' post='1094538']
[quote name='Elliot Cannon' post='1094533' date='Oct 24 2008, 11:54 AM'] You can't PULL a liquid! [/quote] Yeah, but if the pump is lower than the tank, it could still be located in the engine bay... fuel would run to the engine bay even without a pump (IMG:style_emoticons/default/biggrin.gif) That's exactly my point. If the pump is lower than the tank, the static pressure to the pump is the same, weather the pump is in the front or the back. |
Root_Werks |
Oct 24 2008, 05:02 PM
Village Idiot Group: Members Posts: 8,425 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
[quote name='Elliot Cannon' date='Oct 24 2008, 03:46 PM' post='1094600']
[quote name='Todd Enlund' date='Oct 24 2008, 12:59 PM' post='1094538'] [quote name='Elliot Cannon' post='1094533' date='Oct 24 2008, 11:54 AM'] You can't PULL a liquid! [/quote] Yeah, but if the pump is lower than the tank, it could still be located in the engine bay... fuel would run to the engine bay even without a pump (IMG:style_emoticons/default/biggrin.gif) That's exactly my point. If the pump is lower than the tank, the static pressure to the pump is the same, weather the pump is in the front or the back. [/quote] Yup, being a Boiler Sup and dealing with Hydronic loops/pumps all day, liquid doesn't lend to being sucked or pulled very well. Loves to be pushed as we all know it's a non-compressable. (IMG:style_emoticons/default/wink.gif) I'll move my pump to the front at some point. But not right now. |
Lo-Fi Version | Time is now: 27th September 2024 - 01:38 PM |
