My MicroSquirt Install |
McMark |
Jul 20 2008, 05:00 PM
I'm installing a MicroSquirt system.
This thread IS NOT A MS/SDS/Carb DEBATE! If you don't like MS please leave. I'm tired of the endless, worthless debate. Anyway, now on the the fun stuff! I am using the TPS off of a Volvo 850 because it's a Bosch sensor (I like sticking with OEM manufacturers when possible), fits the D-shaft throttle and is appropriate for MS. I made the adapter plate today. Attached image(s) |
type47 |
Nov 14 2008, 05:11 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
what is the compatibility between MS and the type of camshaft? is MS sensitive to agressive cams like D-jet? the reason i ask is my "next" motor is to be a 96mm digital FI motor but i have a "race" motor on the floor that had carbs. i don't remember the specs on the cam, i have the build sheet, but i'd bet it was a carb cam. so my question is (to save me from building a motor up from the crank), can i install MS on this "race" motor?
Rick_Eberle |
Nov 14 2008, 05:38 PM
Member Group: Members Posts: 390 Joined: 14-January 04 From: Geelong, Australia Member No.: 1,558 |
what is the compatibility between MS and the type of camshaft? is MS sensitive to agressive cams like D-jet? the reason i ask is my "next" motor is to be a 96mm digital FI motor but i have a "race" motor on the floor that had carbs. i don't remember the specs on the cam, i have the build sheet, but i'd bet it was a carb cam. so my question is (to save me from building a motor up from the crank), can i install MS on this "race" motor? You can tune it around any cam. MS can be switched from "Speed Density" (Manifold Pressure) to "Alpa-n" (RPM-Throttle Position), or with the EXTRA code, a blend of the two. |
Lo-Fi Version | Time is now: 27th September 2024 - 11:45 AM |
