> 914 –with 930 trans?, Hydraulic clutch?
burton73
post Nov 26 2008, 05:21 PM
burton73
As the new car that I have coming to me does not have the master cylinder for the 930 box I called Easy wrecking and went over my options of putting a G-50 Clutch and brake assembly in. They have one for $250. but they think there will be a lot of work to modify it to fit and may not be the best bet. They said Tilton has some Hydraulic clutch set ups. I would like to know of some ideas that you guys may have for the setting up of the Hydraulic clutch on my 930 trans that has dropped some LSD.
Thanks,
Bob
andys
post Nov 26 2008, 06:55 PM
I mounted a Wilwood clutch master using a bellcrank setup off the stock pedal assembly. The master will eventually hide behind the console that I'm yet to install. This of course requires some amount of fabrication.
Consider also using the stock cable to actuate a master located next to the trans; use a similar bellcrank setup and a short hydraulic line. This avoids messing with stuff in the cramped space by the pedal cluster. Just a thought.
Andys
burton73   914 –with 930 trans?   Nov 26 2008, 05:21 PM
Bruce Hinds   I'm sure someone here will direct you to the t...   Nov 26 2008, 06:03 PM
wbergtho   I bought a Tilton MC (15/16") and installed i...   Nov 26 2008, 06:11 PM
byndbad914   I have the Tilton triple pedal assy - actually one...   Nov 26 2008, 06:30 PM
byndbad914   note this had a rod end and a super simple bracket...   Nov 26 2008, 06:33 PM
burton73   This is the factory floor set up for a G-50 from a...   Nov 26 2008, 06:43 PM
burton73   You where on this faster than me. Bob   Nov 26 2008, 06:49 PM
andys   I mounted a Wilwood clutch master using a bellcran...   Nov 26 2008, 06:55 PM
Larry Hubby   I mounted a stock 944 clutch master cylinder next ...   Nov 26 2008, 07:30 PM
burton73   You guys have given me some great ideas. Andy’...   Nov 26 2008, 09:41 PM
Larry Hubby   The yellow cap is just a plug on the input nipple ...   Nov 27 2008, 01:38 AM
burton73   “So, as you can see, it goes on the outside (but...   Nov 27 2008, 06:07 PM
Larry Hubby   Sorry for the delay in answering your questions, t...   Nov 29 2008, 03:59 PM
Dr Evil   Larry, you are amazing. I am glad you are on our s...   Nov 29 2008, 04:41 PM
Wilhelm   I derived a similar solution. This way I can work...   Nov 29 2008, 07:26 PM
burton73   I have decided to install a full late Carrera sus...   Nov 30 2008, 12:25 PM
burton73   Wilhelm, I find the Clutch pedal Wilwood 340-1289...   Nov 30 2008, 01:25 PM
burton73   I have found the Wilwood Part Number: 340-1285 ...   Nov 30 2008, 04:16 PM
Wilhelm   That would be the correct double cylinder pedal pa...   Nov 30 2008, 05:44 PM
burton73   If you look closely the throttle pedal has a label...   Nov 30 2008, 07:16 PM
Wilhelm   I am using this pedal because I am using this engi...   Nov 30 2008, 07:30 PM
burton73   That is gorgeous. :wub:   Nov 30 2008, 08:15 PM
burton73   Wilhelm, thanks for making me up this piece Bob ...   Dec 17 2021, 02:59 PM
burton73   Bob B   Dec 17 2021, 03:04 PM
- Lo-Fi Version Time is now: 23rd November 2024 - 10:56 AM
