Tie-rod removal, I'ts stuck |
watsonrx13 |
Jan 19 2004, 03:42 PM
Advanced Member Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
I used Brad's method of tie-rod removal (courtsey of Jeroen):
1. with the car on jack stands, jack up the a-arm. 2. put another jack stand under the hub of the brake disc, so it supports the whole assembly. 3. remove jack. 4. get the BFH (5 lb sledge hammer) and give a couple of good whacks on the a-arm, the tension on the torsion bar helps pushing the a-arm down. This procedure worked wonderfully on the passenger's side (3 blows and it was off). But after repeated blows, PB blaster, repeated blows, nothing. This went on for about 2 hours. Ok, let's get the tie-rod removal tool (not the tuning fork type). Attached removal tool and tighten. After tightening 3 times, and the tools sliding off the rod, I added a c-clamp to keep the arms from expanding. Again, I tighten the screw down until I couldn't tighten anymore. I added PB blaster and let it sit for 2 hours, while I removed the passenger's side brake. I went back to the driver's side tie-rod, but no movement using the removal tool. Can the tie-rod threaded shaft be bent enough that I should cut it off? Should I try again tomorrow? (I'm leaving the removal tool and c-clamp attached overnight) Attached image(s) |
watsonrx13 |
Jan 20 2004, 04:27 PM
JP,
Your technique worked perfectly, one smack on the top of the removal tool with the BFH and it was FREE. Thanks again to everyone who made recommendations. Attached image(s) |
Lo-Fi Version | Time is now: 27th September 2024 - 07:54 AM |
