Newbie Question, My new pressure gauge is screwed |
kkid |
Jan 15 2009, 05:12 PM
Member Group: Members Posts: 343 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California |
Please educate me if you know.
This is the back side view of a fuel pressure gauge that I bought today. And I noticed there is a very small screw in the center of the inlet. Don't know what to do with it. Thanks in advance! |
Aaron Cox |
Jan 15 2009, 06:30 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
Does it block the hole completely?
The pressure either pushes against that screw (and then the gauge reads that pressure) or it goes around the screw into something else |
So.Cal.914 |
Jan 15 2009, 07:35 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
Does it block the hole completely? The pressure either pushes against that screw (and then the gauge reads that pressure) or it goes around the screw into something else Hi Aaron! I thought the same thing. Googled it but ran into a wall. I would not remove it until you contact their tech support. |
Lo-Fi Version | Time is now: 27th September 2024 - 12:21 PM |
