Full Flow Engine Mount, For FF Gene Berg covers and 30mm+ pumps |
Mark Henry |
Apr 18 2004, 12:32 PM
Anyone who wants to run a plugged Type one 30mm pump with a Berg, Raby (or equivalent) FF cover, so that you can use a remote filter adaptor, oil T-stat, and cooler.
Gets rid of restrictive sandwich adaptors and the stock filter mount. More flow means better oil pressure for running those long lines to a front mounted cooler. Using a Gene Berg pressure relief cover (std cover shown) means you never have to worry about cooler blowouts even on the coldest mornings. Fully gusseted, stronger than stock, bead blasted and painted black (the yellow was to make it show up in the pic) or raw so you can powder coat it. Will only work with the 30mm (or larger) pump. $90. (USD) + core, includes return postage. ($25. core charge) Stock filter mount delete plate an extra $10 with mount. PM me for shipping details Attached image(s) |
race914 |
Feb 7 2009, 07:40 AM
73 914-4 Group: Members Posts: 1,006 Joined: 31-October 05 From: Nipomo, California (Central Coast) Member No.: 5,027 Region Association: Central California |
Anyone who wants to run a plugged Type one 30mm pump with a Berg, Raby (or equivalent) FF cover, so that you can use a remote filter adaptor, oil T-stat, and cooler. Gets rid of restrictive sandwich adaptors and the stock filter mount. More flow means better oil pressure for running those long lines to a front mounted cooler. Using a Gene Berg pressure relief cover (std cover shown) means you never have to worry about cooler blowouts even on the coldest mornings. Fully gusseted, stronger than stock, bead blasted and painted black (the yellow was to make it show up in the pic) or raw so you can powder coat it. Will only work with the 30mm (or larger) pump. $45. (USD) + core, includes return postage. ($25. core charge) Stock filter mount delete plate an extra $5. PM me for shipping details Mark, I'd like to buy one of your full flow engine mounts. PM sent on the 5th with shipping location. Let me know the total and your preferred payment method. Thanks for producing these! Greg |
race914 |
Feb 9 2009, 12:30 PM
Anyone who wants to run a plugged Type one 30mm pump with a Berg, Raby (or equivalent) FF cover, so that you can use a remote filter adaptor, oil T-stat, and cooler. Gets rid of restrictive sandwich adaptors and the stock filter mount. More flow means better oil pressure for running those long lines to a front mounted cooler. Using a Gene Berg pressure relief cover (std cover shown) means you never have to worry about cooler blowouts even on the coldest mornings. Fully gusseted, stronger than stock, bead blasted and painted black (the yellow was to make it show up in the pic) or raw so you can powder coat it. Will only work with the 30mm (or larger) pump. $45. (USD) + core, includes return postage. ($25. core charge) Stock filter mount delete plate an extra $5. PM me for shipping details Mark, I'd like to buy one of your full flow engine mounts. PM sent with shipping location. Let me know the total and your preferred payment method. Thanks for producing these! Greg Email sent |
race914 |
Feb 12 2009, 09:20 AM
Anyone who wants to run a plugged Type one 30mm pump with a Berg, Raby (or equivalent) FF cover, so that you can use a remote filter adaptor, oil T-stat, and cooler. Gets rid of restrictive sandwich adaptors and the stock filter mount. More flow means better oil pressure for running those long lines to a front mounted cooler. Using a Gene Berg pressure relief cover (std cover shown) means you never have to worry about cooler blowouts even on the coldest mornings. Fully gusseted, stronger than stock, bead blasted and painted black (the yellow was to make it show up in the pic) or raw so you can powder coat it. Will only work with the 30mm (or larger) pump. $45. (USD) + core, includes return postage. ($25. core charge) Stock filter mount delete plate an extra $5. PM me for shipping details Mark, I'd like to buy one of your full flow engine mounts. PM sent with shipping location. Let me know the total and your preferred payment method. Thanks for producing these! Greg Email sent (IMG:style_emoticons/default/icon_bump.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 08:54 AM |
